If you have a 16+, there is a pigtail behind driver's side taillight controlled by the bed light switch.Anyone tapped into cargo lights when adding your bed lights. I want them to function like my Sierra did, when cargo light switch is activated. I just don't know the easiest place to tap cargo light wire?
Interesting. Yeah I have a 17, so hopefully it's there. Are there any pics of the pigtail on the web?If you have a 16+, there is a pigtail behind driver's side taillight controlled by the bed light switch.
Sent from my E6810 using Tapatalk
Just did it on my '18 this weekend. Prior post is correct, should be a connection point under the driver-side tail light that works off the same switch for the cargo lights. Easiest to see if you slide under the truck and it'll be up higher than you'd think. Can't really see it if you pull the tail lights (which I'd recommend anyways, just makes fishing the wires easier). My '16 had two small wires about 2-3" long coming out of the end of the connector, my '18 just had a dead-plug in the connector. Follow the tail-light harness up to the tail light and you'll find it. Easiest to remove the connector if you take it off the truck mounting (like a little gray barbed insert). Slide the gray tab back, push down and pull it out! If you've had the truck a while, wear safety glasses, I was amazed at the crap that fell off it even on the new one!Interesting. Yeah I have a 17, so hopefully it's there. Are there any pics of the pigtail on the web?
Thanks
Very nice! do you have a write up on your install? Didn't find one.I did this mod with a self made harness. Spliced some waterproof connectors into the factory pigtail:
And used some VHB tape to attach some water proof LED strips to the underside of the bedrails:
The result is nice even light bright as hell and costs a fraction of that the OEM system would have:
Very pleased with the result. The circuit is tied into the factory system so it's fused and timed properly with the factory bed light switch. Plus I added a couple lights under the back bumper to act as backup/reverse lights.
I am mainly interest in the connectors you used to splice into the pig tail and those LED strips, those are really bright!
Thanks!
Glad you like them. I diddnt do a write up but I posted about them here: http://coloradofans.com/forums/201-...331201-bed-lighting-addressable-rgb-rope.htmlDo you have a link for those LED strips by chance?
If you want to operate it with the cargo light switch it's a little complicated but I believe a member posted how he did it.so for those of us with a 15 without the pigtail gift, where do we splice in, at the trailer hitch harness?
In that thread there is talk of wiring both ends of the LED strip... did you wire both ends of the strip or just 1 end? ThanksGlad you like them. I diddnt do a write up but I posted about them here: http://coloradofans.com/forums/201-...331201-bed-lighting-addressable-rgb-rope.html
My post start at #11. There should be current links to the waterproof connectors and the 5050 LED Strips.
Its not much of a build, but if you have any other questions let me know.
Just to one end. I did three separate plugs into the factory pigtail. One for each side of the bed lights. That way if one side dies, I can swap out just that side. The third plug is for the work/reverse lights I hung off the back bumper.In that thread there is talk of wiring both ends of the LED strip... did you wire both ends of the strip or just 1 end? Thanks![]()
