I have had one of these cargo bars for the last 5 pickup trucks I've owned. Works great for just the things you are wanting to hold in place and even larger items . .It's compact and not in the way when you don't need it.What’s everyone using for bed divider? I’ve seen the gear on divider and not really impressed. Mainly want to divide the rear couple feet closest to gate from the rest to prevent propane tanks, gas containers from shifting around.
If you have a picture that would be great!I just use a nice 2 x 6 that I drop in the slots that are already in the sides of the bed. I cut the corners of the two by sixes slightly so that it goes down all the way. Perfect for what you’re talking about they think and super cheap. I can send a picture if you want to see.
That is a 2x6 I believe.Here you go. Actually looking at this I think it is a 2 x 4 that I have back there. You could easily do something much bigger, and I have mine cut so it’s very snug it does not move around or rattle. Works great for keeping stuff from moving around in the back half of the truck and you can move it forward and back in those two slots you see on the side. Super cheap solution.
I think you're right. So you could easily do a 2x8 if you needed more of a "wall" back there. So far this has been handy as it is.That is a 2x6 I believe.
I cut one, it sits in my garage along the wall behind my workbench, fairly easy to grab when I need it. I would consider cutting slots for handholds in it if I used it very much. But I have only used it 2-3 times since I made it.
I believe mine is actually a 2x8. I placed it in the slots behind the wheel wells (between wheel wells & cab). In that position, it was high enough that 4x8 sheets of wood could be supported by the 2x8 in the bed and my raised tailgate, above the wheel wells.I think you're right. So you could easily do a 2x8 if you needed more of a "wall" back there. So far this has been handy as it is.
I'm actually thinking about cutting a slight divot into something like this and lining it with padding so I can have it cradle my kayak and I can carry it with the gate down.
I think you'd be better off measuring your actual bed since there isn't too much room for error and you want a snug fit. There could be variations due to thickness of bed liners, warping of the box, manufacturing tolerances, etcDoes anybody have a chance to measure this long ways? I am trying to make my own and dont want cut it short. Thanks!
