Correct!This is the long travel setup, right? The addition of UCAs, uniball, and coilovers should result in a mid-travel setup, correct?
We need a zr2 LT kit
Why in this setup did you guys go to the outer shock mount on the LCA instead of the inner? What's the difference in each mount?
What I meant was with the coilover.. in the first set up they had it mounted to the inner most mount on the LCA.. now they have it on the second slot which is the outer most position.. just wondering the reasoning between going from that inner position coiler lower mount and the outer. It doesn't look to be a different coilover.. so I'm just wondering why the two options and why they changed.
