Hello All,
How To Section:
Recommended First 3 Mods/Accessories
How To: Inverter + 120v Outlets
How To: Switch Pros 9100, Power Tray, Blue Sea Systems design/install
How To: Rear seat extinguisher mount
How To: 589Fab Skid Plate Support Bracket Install
How To: ARB Twin Compressor install | 589fab mounting bracket | ARB Manifold | S&B CAI
How To: ROKBLOK ZR2 Mudflaps on non-ZR2
How To: DIY Shock Boots - Filthy Motorsports Style
How To: HD Mil type battery terminals
How To: Rago Fab Tailgate Gap Antenna Mounts | + NMO conversion
How To: Fix 4x4 selector knob vs Headlamp knob confusion
Maintenance (mx):
My Consolidated 2.8L Duramax Diesel Maintenance Plan
Checklists: 6L50 Transmission Pan Drop, 2x Diff change, Transfer case fluid change
How To: Bleed Brakes with pressure bleeder
How To: Clean & Shampoo Neoprene seat covers (CoverKing, WetOkole, etc...)
How To: Rear Leafpack replacement in 43 easy steps !
How To: Diesel MAP Sensor Cleaning
Misc:
How To: Four corners rapid air up air down system
How To: Modify Igloo 6gal water containers with spigot & vent
Farkle Factory Aluminum Fuel Drain Plug - Pictures & Diesel Immersion Test
From Diesel Colorado to Electric Car
6L50 Cooler Inlet/Outlet Adapter Plate Comparison
CAO 2/2023:
Stock with my 2005 2500HD Duramax trade in:
CAO 11 Feb 2023
Disclaimer: I don't carry all of the gear all the time. Check boxes toggle whether the weight value is included. I leave all checked for planning/mod purposes and adjust based on the trip.
How To Section:
Maintenance (mx):
Misc:
CAO 2/2023:
CAO 11 Feb 2023
