Hi guys, I finally got around to the dam removal.
I hope this how-to will help anyone wanting to DIY it.
I will say it now, there are others who have done it differently, I know.
This tutorial is done from an outside to inside removal process for simplicity and clarity of instruction purposes.
Overall its a simple process not requiring many tools and can be done on the ground. I’m a scrawny 5-7 170 pounder that can creep underneath and at times I had the dam across my neck. If you’re much bigger than I, I would suggest lifting the front. I did not have to remove the wheels but based on your tools and hands, you may find it gives you more room to move around in. Consider doing this job during your next rotation.
All these pictures are taken of the left side area only. The right side is identical.
The tools I used are:
T-15 Torx (TM) bit
Small ratchet driver for bit
T-15 Torx (TM) socket 3/8
10mm socket 3/8
7mm socket 1/4
2” extension 3/8
finger or thumb drive 3/8
stubby ratchet driver 3/8
7” ratchet 3/8
screwdriver, flat blade
T-15 Torx (TM) bit
10mm socket 3/8
7mm socket 1/4
2” extension 3/8
7” ratchet 3/8
