1 - 20 of 28 Posts
I have put on the easy 3 bolt ons (aem air intake,cherry bomb exhaust and pcm) and I am now looking for another mod to get the extra hp. I am thinking about either a cooling fan or another chip to go along with the pcm. Does anybody know which ones would get the most gains?
Get a turbo, it will make the most HP.
Gut your cat- easy 10 ponies there and Dyno proven
Denso Iridium ITV16 good for gas milage and throttle response
4.2 Throttle body more air and better throttle response.
you are thinking of a throttle body spacer he is talking about a throttle body. i duno if you have a i4 or a i5 but you wont see any gains with the 4.2 on the i5
Discussion Starter #6
Ya your right my fault i got them confused i have the i5. Does any body have a tune with a pcm?
Discussion Starter #8
I am planning on doing that at the end of the month once my tags expire. Does putting in a Jet Servo help the 1/4 time any? I know that it doesn’t help hp but I was thinking it might make things run a little smoother
I've heard the Corvette and JET servos help out, you may get a little sideways in the rain according to some (under heavy throttle)
Creeve, do you have an I-5 with an 4.2 TB?
I do... And their is a gain, search the topic of the 4.2 TB. YOu will find a lot of info about it.
I need to look into this tb issue. Sounds interresting.
Discussion Starter #12
I just passed inspection and I was wondering if anybody took out both their cats and how much gain that was? I understand it will be loud but it seems like if the first one gives you 10hp the second one would have to at least give you an extra 5?
dalcowboys i think if you gut the second cat you will start throwing codes...but i think someone said to put an o2 sensor spacer in and you wont...i dunno someone else will probably chime in and give you more info...i myself just put in a highflow cat because my orginal 2nd cat blew apart...possibly because of the 1 cat mod...im not sure though
Discussion Starter #17
Does anybody know a shop in Houston area that installs the JET Servos? Nobody seems to know what im talking about when I call I would be drive a little if the shops good.
Any transmission specific shop can (should) be able to do it. Look under transmission service in the Yellow Pages.
Alot of people install this in their driveways. A transmission shop should have no problem. What were you asking them specifically?
1 - 20 of 28 Posts
