Hi,
Currently cross-shopping 2 possibilities.
1) diesel gmc canyon slt trim or up wherever best value is found, likely a 17' holdover.
2) diesel colorado zr2
To me they're basically a wash. The canyons would have a bit better mpg, should be better towing and a bit more wife approved.
The colorado on the other hand chubbs me up, and it drove better on road imo, basically I'm a sucker for super trick suspension.
Either vehicle would be staying relatively stock and kept for a minimum of 2 years (business reasons) and potentially turned over or refreshed afterward.
My current work truck/tow rig is an 8ft bed cummins 3/4 ton. Tows my open aluminum car hauler like nothing, same with a 24ft enclosed that spends most of its time as a garage bay. That would be going away through atleast the spring, at which point if necessary an older, cheaper, 2wd version would be purchased.
Likely I'll go with whatever direction hits my set numbers first, and pick up a cheap 2wd tow pig from the south next year if necessary.
There is however a high chance of pulling the open trailer with a 2-3k car on many short trips and occasional long trips with the twin.
Anyone have actual experience towing with a zr2? Mostly looking for feedback on stability. I assume its somewhat compromised
