1 - 17 of 17 Posts
Sooo, looking into doing this.. if I can get it done for cheap enough, I am going to do it, If I cant them just building the POS auto,, so no promises.
But right now i'm just getting prices and stuff together so I have a good idea.
Here is what I know I need so far.
Tranny
Clutch
Cluster
Shifter
Master Cylinder
Slave Cylinder
PCM retuned
Plumbing (for Master/Slave cylinders)
Am I missing anything?? let me know, and if anyone has anywhere I can find a tranny of master/slave cylinders or any plumbing please let me know..
Yeah I need to call them, we have one in town but for some reason it isn't on their site, Ill have to find the number.
need the flywheel, but you knew that already
the cluster probably isn't necessary if you want to wait on that.
Discussion Starter #6
damn ebay sucks, I've searched so many times for Colorado stuff and that ^^ is the most I've seen everytime I search I get 0 results.
thanks guys..
Anyone know how hard this maybe? (im hoping more have looked into it more then me lol) I know its not going to be easy, but just wondering if its going to be pain in the ass, why the hell did I do this kind of hard or not.. lol
I've contemplated doing it but just haven't done much research on it. I don't know, some vehicles it's a fairly easy and straightforward process and some end up just being a PITA. There's no good way to know until someone steps up and does it.
I don't think it is, I think the clutch pedal assembly bolts right on to the current pedal assembly. I could be wrong though, someone with a 5 speed needs to check for us.
Discussion Starter #13
PCM for less can retune it for me, pretty sure I dont have to get another harness..
scrapped the Idea tho, it was gonna cost close to 1,000 just in parts and who knows what else I mite run into and need to change, just going to rebuild the auto, it is cheaper and that means I can do other stuff to the truck too..
Discussion Starter #15
well a friend of mine that I used to work at the dealership with (he is still there) they are rebuilding it for me for around $500
Discussion Starter #17
you put it out then pull it apart and replace all the clutches and crap and all that good stuff inside of the housing.. yeah it should be a little stronger
1 - 17 of 17 Posts
