I aplogize in advance if there is another thread somewhere about this, I did a bit of searching but didn't find quite what I was looking for.
So I've been wanting to mount KC lights on my 2004 Chevy Colorado Extended Cab with factory fog lights with rocker switches. After some research and a bit of help, I was lend to Otrattw for my switch needs. I found the switches I want and I have the type of wire, fuse, mounting place and such picked out; my only problem is I don't know where to wire the switches to on the truck itself. They are Contura II, Red Lens, Upper Independent, Incandescent lights, and i want them to work along with the dash lighting; including the auto light system. What wires on the truck do I tap into to meet this. Not sure if it helps any but I am going to mount them between the visors above the rear view mirror with an inline fuse in the engine bay.
Switch Diagram:
http://www.otrattw.com/J66a.pdf
Switch Diagram:
