Ok, so am I correct to say I have a locking rear differential in my Z71 and a LSD in the front? If so why does the ZR2 have button for for the rear differential. Why not just shift into 4 wheel drive and turn on the front locker? I'm getting there lol. I think
Yes and no.
Yes, you have an "automatic locker" in the rear. When one rear tire spins 120 rpm faster than the other, centrifugal force engages the locker, engaging both rear wheels together.
No, you do not have a LSD in the front. You have an open differential. An open differential gives equal torque to each tire. If one wheel is on a slippery surface and only requires 20 lb ft of torque to turn, and the other is on dry pavement and requires, say, 75 lb ft of torque to turn, then the slippery one will spin at 20 lb ft and the tire with traction will not, because it's only getting 20 lb ft.
A ZR2 has a "manual selectable locker" in the front and rear axles. It runs as an open differential until you activate the switch, which electrically engages the locker. There are other types of selectable lockers as well, such as the ARB air activated locker, or the OX cable activated locker.
Automatic lockers are suitable for on road use, not so much for serious of road use. Selectable lockers are intended for off road use.
So, the binding I feel is not between the solid axle of the rear but between the front and rear axle when turning on dry pavement in 4x4 mode?
That is correct. When you turn, each wheel on your truck is traveling in a different size circle, and therefore must each travel at a different speed. The extreme is the inside rear wheel and the outside front wheel. The outside front wheel is traveling much further than the inside rear, so it has to turn faster. So when you put it in 4x4, you are locking the front and rear axles together in the transfer case, thus the binding.
Hope that all makes sense!
