3rd Gen Aftermarket Wheel/Tire Thread
3094 Views 16 Replies 9 Participants Last post by  FireNative2
Lets get a database going to help other members figure out what wheel/tire combos fit, what doesn't, or what it takes to fit. Can use the template below!
MODEL
Put Make/Model/Trim here!
WHEELS
Make/Model:
Size:
Offset:
TIRES
Make/Model:
Size:
MODIFICATIONS
Put lift/trimming info here
PHOTOS
Reactions: 1
1 - 17 of 17 Posts
5
MODEL
2023 GMC Canyon AT4
WHEELS
Make/Model: AEV Salta XR
Offset: +5mm
TIRES
Make/Model: Falken AT3W
MODIFICATIONS
No modifications
PHOTOS
See less See more
Reactions: 5
285's and no rub? No lift or anything?
About damn time. I guess I'll find out if 295's fit on the ZR2 if I ever get mine
MODEL
2023 Chevy Colorado Z71
WHEELS
Make/Model: Black Rhino Armory in desert sand
Offset: +6mm
TIRES
Make/Model: stock
MODIFICATIONS
1/4" spacer up front. Was rubbing on the calipers
Wheel Tire Sky Land vehicle Vehicle
See less See more
When changing the overall diameter of the tire is there a way to fix the speedometer?
Not yet. There may be an option that's for the Silverados that will work for us too, but I'm not sure.
prety sure the RC/Hyper tech speedocalibrator will work on the new trucks, as it works on the 2nd gen and 2023 silverados
Hi, i thinking of getting AEV Crestone dualsports for my Denali in either 17“ or 18“. I don’t want to deal with hub rings so i plan to get them in the factory bore and wrap them in 33” rubber. My problem is that the new spec wheels don’t appear on AEV or gm performance catalog yet let alone figuring out shipping up North
You will likely need to wait for quite some time for the Crestones to come in a factory bore, if ever.
Very few aftermarket companies make wheels with factory bores. Usually make them to the largest and use rings to bump them down for other fitments.
If you must, then you might want to wait to see if the Bison comes in some variation of the Crestone and obtain those. Also, I don't see AEV really ever making an 18" unless its required for some fitment reason.
The new Silverado zr2 bison rides on non bidlock capable 18” crestones. I have not seen these used in other applications unlike the 17”s that I have seen on broncos and tacos. I just have to wait and see if they show soon
What IS the factory bore size for the 2023s?
thx
7
MODEL
2023 GMC Canyon AT4
WHEELS
Make/Model: KMC GRS MACHINED W/ SATIN BLACK LIP
Offset: +0mm
TIRES
Make/Model: Nitto Ride Grappler
MODIFICATIONS
No modifications
Zero rub at full lock.
See less See more
Reactions: 5
thx
78.1 same as the Silverado.
Subscribed! Awesome photos in here, looking forward to future posts :cool:
Reactions: 1
This youtube video shows a 23' Colorado Z71 with 33" tires with zero off-set. So the 23' Canyons and the Trail Boss and ZR2 should have a little more room with their factory lifts, but its close.
See less See more
There's a dedicated thread for wheels/tires here: 3rd Gen Aftermarket Wheel/Tire Thread
thanks I'll ask a mod to move it there
Reactions: 1
1 - 17 of 17 Posts
