1 - 5 of 5 Posts
I am wanting to lift my 4Dr 4x4 Z71. I plan on adding a 3in strut spacer and a 1-1.5 rear lift block. I plan on adding the sway bar drop, extended end links, and dropping the diff. Would this set up be safe? I know that i need an alignment and anytime you lift truck things will wear faster but want to make sure this would be safe. Thanks in advance!
You could do that but it might be better to do a 2 inch spacer and 1.5 inch body lift, less wear on front end components. A number of guys do that. RC does a 3inch lift and some guys have binding issues and creaking noise with it.
check out the lifted section for ideas..
I installed the 3” street rays spacer sway bar drop and extended sway links and nothing in the rear. Personally I like the way it sits. It’s about a inch higher in the front. It rides perfectly fine.
388667
388668
I would do a 3" suspension (not spacer) lift in front with a 1" block in back.
1 - 5 of 5 Posts
