1 - 7 of 7 Posts
Does anyone know if i can fit 31s under a 2wd z85 without lifting it and if not what is the largest size i can go?
They say it will work - I getting ready to try here pretty soon. - But I think I may also get a front coil spacer and AAL or maybe just a hocky puck body lift - I don't know yet - I'm still trying to decide on what brand and model tires - and if I should run a more aggressive tread on the rears and a milder tread on the front. Or the same tread all around.
with stock wheels at stock height you will probably rub a little.
I think I'm just going to go with the 30X9.5 after all - mainly due to the 6.5" wide rim. And I won't need to lift it. I only have a 4X2 with the I-4 anyway, so it would probably be a better fit all around on my truck.
1 - 7 of 7 Posts
