1 - 7 of 7 Posts
I was wondering how bad it would rub.
im not really asking if it would rub
just how bad
if its like completely not do-able what tire size looks the best that keeps the fenders still looking full
TIA
if I'm not mistaken thats the stock tire size...you shouldn't rub but if you do it will only be when you hit a good sized bump/dip
yeah you are right that is the stock tire size.
thats good to know
i thought i was going to have to replace tires and get a tire with less side wall.
Thanks
you WILL rub up front on turns and bumps...quite a bit really.
rears are fine, but you need a smaller front tire
damn i was thinking that because i just went out and looked and the inside wheel well has a sort of a bump that looks like it would hit the tire.
what size tire keeps the wheel well looking full though without rubbing? i dont want a tire that looks too small leaving a gap between the top of the tire and the bottom of the fender.
1 - 7 of 7 Posts
