1 - 20 of 24 Posts
I have a 2018 LT with an auto spring level/lift (2.5” front, 1” in the rear)
A couple of days ago I ordered a set of 20x9 0mm anthem equalizers and some 275/55r20 nitto ridge grapplers. I’m looking for some insight or possibly some pictures of someone who is running a similar setup to possibly get a visual of whether or not I’ll want to order spacers. I will also shortly be ordering fender flares and painting them to match, so as long as they don’t stick out some ungodly 4-5” I think I’ll be okay with them sticking out a little.
Thanks in advance,
Alex
Here is some reading for you.
Discussion Starter · #3 ·
I’ve looked for days for similar setups and only found one or two and as soon as I posted this I scrolled down and saw that. Good looking setup @Speedy4x4
I did a 2" front and i made a lean shim for pass side.
Your wheels will stick out 18mm farther than mine, but if going anither .5 higher, will be sucked in a hair more.
Discussion Starter · #5 ·
I just ordered 1.5” spacers which should have it just barely outside the wheel well with the fender flares.
I will be taking more pics, but might have to wait till next weekend.
I have a 4.5 hr drive to Louisville later, for work this week, going to see if i can get some pics down by the Jim beam distillery, a good winery close to there also.
What pics would you like?
Yours will stick out .7" farther than mine, if you did 2", but going higher might be .5"
I will get some pics of height measurements tomorrow in hotel parking lot, nice and flat parking lot
Thanks in advance,
Alex
399345
I’m running a 275/65/r20
You should be fine without any spacers .
I believe i have a -12 offset
Nice, you got a 275/65R20
What lift? And trim ? Rub?
I was debating on a 60, but a 34.1" tire in a 65 I thought would be to tight
Reactions: hamrickac
Discussion Starter · #9 ·
That was actually the original size I was wanting to go with and everything I read said it wouldn’t fit.
I just have a 2in RC leveling kit.
I had to trim the plastic piece in the front of the wheel well back about 2in and in the rear there is a pinch weld that i bent back too.
It rubs a tad bit at full turn .
Discussion Starter · #11 ·
I’m sure glad I didn’t go with the 275/65r20 because these are rubbing like crazy on both the “waffle” piece that the inner fender connects to and the rear portion of the fender well. I looked through the forums for anyone who has ran into rubbing like this, but can’t find anything. Does anyone remember a thread or know what to do?
What did you end up going with ?
There are detailed threads on wheel well mods
Discussion Starter · #15 ·
Some pictures of the wheels/tires and rubs. I’ll be modifying this weekend or next week because I have the whole week off. Monday the fender flares will come out of paint and the wheels should be pretty close to flush with them.
399522
399523
399524
399525
S
399521
Black 2017 Canyon Denali CCSB, 2.8 Diesel, 4x4
I have LT275/55r20 Ridge Grappler on stock Denali wheels with a 1” spacer.
I trimmed the wafer piece in the front holding the lining back to the next ridge to clear the front. To clear the rear, I bent the pinch weld back and cut away the plastic portion that cover the pinch weld.
I don’t have anymore rubs. Hope that help.
Discussion Starter · #17 ·
Well after way more cutting then I thought I’d have to do the rubs are gone (other than figuring out how to hold back the well liners) I left the black piece off because my flares will be out of the paint booth Monday.
399560
399561
alot closer than mine.l, here is acouole pics we can compare.
275/55r20, just different offsets.
1 - 20 of 24 Posts
