1 - 4 of 4 Posts
Hey guys,
Any one know if 265/70/17 tires will rub on a stock 2021 zr2 suspension? I plan to get 1-1.5 inch level spacer on the front, but want to get the tires first.
TIA.
From all accounts, no, not unless you run it with aftermarket 0 offset wheels. With stock wheels and stock suspension, 265/70/17 should not rub at all. I'm actually planning to run that tire size on my stock ZR2 soon.
I have ordered a set of ridge grapplers in this size.
My plan is to run them stock initially, see how I like the look, and ensure there is ZERO rubbing in any conidtion.
If there is ANY rubbing--I will install the eibach spring lift/level kit...and THEN opt for 1.25" spacers.
It's my understanding that with the spacers, that there will be rubbing even with the Springs, and will therefore require minor trimming.
I'd prefer not to trim at all, but we shall see...
1 - 4 of 4 Posts
