1 - 12 of 12 Posts
· Premium Member
2022 Colorado Z71 Crew Cab 4x4 Summit White
Looks nice. Far more work than I'm capable of doing, but I like it!!!
· Registered
Discussion Starter · #3 ·
Don't let it intermediate you! as far as the internal lights it just plugs into the outlet in the back and wire management is huge. I just hid mine under the panels on the door frame running from the back to the front. Just take your time never rush cause that is when things start to not work.
As far as the light bar under the tail gate I hard wired it in but I am also an electrician. It comes with the feature just plug into 4 pin trailer outlet so you would just have to worry about mounting it. But i would suggest if you want it to be hard wired get it done by a competent person.
· Registered
· Registered
I need rear footwell lights, hmmmmmm got me thinking...
OP now all you need are puddlelights, open the door and the ground lights up so you can see what you may be stepping in...there is a write up in the how to section
Reactions: B3N01T93
· Registered
Discussion Starter · #8 ·
Dimmable? Seems bright for while driving. I'm assuming they come on when you open the doors too?
Dimmable can change colors do hundreds of different scenes. Everything can be controlled by your phone. Its a great product
· Registered
Discussion Starter · #9 ·
What brand are the lights? Where did you get them? Looks good!
Below is the link from amazon. They are Govee lights. They have a light of different kinds of light strips these I found are the best for cars and little trucks.
· Registered
Any good suggestions on puddle lights?
Reactions: B3N01T93
· Registered
With my tailgate light bar it came with a plug and play harness that is a direct plugin to your factory trailer harness so I don’t have to run it to my 4 pin. I love my tailgate light bar. Your inside lighting looks good!!
1 - 12 of 12 Posts
