121 - 140 of 149 Posts
Discussion Starter · #122 ·
Forgot to keep this updated. Here you go!
Cleghorn Trail, Night run
412575
412576
Discussion Starter · #123 ·
Out visiting Santiago Peak, Orange County, CA
412763
412764
412765
412766
412767
412769
412770
Discussion Starter · #124 ·
Moab, Utah - Fins and Things
412772
412773
412774
412775
412776
412777
Discussion Starter · #125 ·
More gear for the Bison
Still need a sleeping solution until I get my bed sleep area worked out. The ROAM adventure co awning / room should hold me over and offer some shade on the days where I don't need the enclosure. Super easy installation on the ARE Ascend roof basket and picked up some 105L cases and a couple coolers for short trips and I don't need the fridge.
412779
412780
Needed to make room for the future fridge and the Goose Gear 60% rear seat delete is installed
412781
Stock rear seat to Goose Delete happens pretty quick
412782
412783
Discussion Starter · #126 · (Edited)
The last trip from Moab Utah:
Discussion Starter · #127 ·
Just finished the Installation video on the Goose Gear Rear seat delete (60% Driver Side)
If you have a Colorado or Canyon CrewCab and you either need more space for gear or need a more adequate space for your pet to accompany you on your outdoor adventures this might just be the perfect product.
For me, I am planning the addition of a permanently mounted fridge and wanted a secure panel to mount to. The folded down factory seat just bounces with the weight of a fully loaded fridge and sits much too high and takes its toll on the seat leather and padding.
Coming soon: Part II - Passenger Side Rear Seat Delete
2021 ZR2 CCSB Bright Blue Metallic
I don't mind sharing my final results once i get the video done. I am still revising the design...probably not going with the Topper EZ lift. After speaking to a few owners and the novelty wore off there are a few problems with the design that are not good for those that drive hard or for extended periods off road. Great on the street but on washboard roads and articulating over obstacles there are lots of alignment problems.
After offroading on washboard roads I did notice a change in alignment that I adjusted when I got back home. If it happens again I think I'll make locator blocks that fit snugly into the 4 stake bed pockets and screw to the underside of the ARE topper flange. That way when the shell is held down by the jack screws, the fore/aft and left/right alignment will be controlled by the alignment blocks rather than the shafts of the jack screws.
I love your build (and YouTube content). It is quite extensive. If you decide to go with the topper EZ-Lift you will need to modify the design of your slide out components since the rear jack screws would go through your sink/fridge drawer and foot platform slide. For a sleeping solution you might want to go with the Nomad bimini tent like Yeti has - which does not need the lift system.
Blessings.
Roy.
Blessings.
Roy.
Fwiw, I love my Nomad tent set up. I can store the whole set up inside my truck so I have it with me whenever I want it. (Naps are good, m'kay)
Discussion Starter · #130 · (Edited)
AEV Highmark Fender Flares are labor intensive but so worth it.
Front Flare installation went well and the results are as expected ... top notch
BEFORE:
415236
AFTER:
415237
They eat up the 33s and make them look small
The new front fenders and templates
415238
415239
Template transfered
415240
Fender cut
415242
Pinch Seam Trimming
415243
Lower fender mount and seam plate with body panel adhesive (3m 8116)
415244
Bison Closeout modification
415245
Finished minus inner fender liner
415247
2021 Sand Dune Metallic ZR2 Bison
BEFORE:
AFTER:
Template transfered
Fender cut
Pinch Seam Trimming
Looks really good. Great work. Dumb question - on the AEV website, do I need to put 2 of each “kit” in my cart (front and rear)? Or just one and that entails both L and R flares? Thanks bro.
Discussion Starter · #132 ·
They come as separate front and rear kits. Each kit comes with both left and right flares.
The rears are the same for both ZR2 and ZR2 bison
The front has 2 models: one for ZR2 front bumper and a different one for ZR2 Bison front bumper
Discussion Starter · #133 · (Edited)
Stock ZR2 Bison Fender Flare with AEV 33" tire trim kit
Tire Wheel Car Vehicle Automotive tire
Removed the modified fender flares and layout the cut template
Hood Vehicle Automotive tire Motor vehicle Bumper
Transfer the cut line to the fender
Automotive tire Tread Hood Motor vehicle Tire
Cut the fender according to the template
Automotive tire Motor vehicle Tread Bumper Tire
Install new Highmark fender flares
Tire Wheel Automotive parking light Car Vehicle
The finished product
Discussion Starter · #134 ·
Time for the shock upgrade
Front - King adjustable coilover vs DSSV coilover (with Eibach Pro Lift Kit)
Light Blue Product Green Line
Rear - King adjustable vs DSSV
Light Product Blue Gas Electric blue
Front - Lower coilover mount
Bicycle Automotive tire Tire Bicycle wheel Vehicle brake
Front - Sway bar relocation
Automotive tire Tire Tread Automotive exterior Bumper
Front - Remote reservoir mount
Vehicle Automotive lighting Motor vehicle Drinkware Gas
Finished results
Tire Wheel Car Vehicle Automotive side marker light
2021 ZR2 Bison, duramax diesel and completely stock .
Mucho $$$$ investment in an already capable rig . Nice .
Discussion Starter · #136 ·
Its just as much fun working on the rig. It absolutely capable but who doesn't like a little bit more?
Discussion Starter · #138 ·
Yes. Yes I should.
Wait, no I should not. If I like it then I'm going to want Kings. Sh!t!! 🤣 🤣
You should drive it! Then you can report back so we can all spend more $$.
Being serious, I thought I had read somewhere that the Kings require more frequent rebuilds. True? Or was that Icon's?
