Surely this has been covered before but I haven't found the answer yet. Just went to change the oil and filter. After draining the pan, removed the filter cap and the filter housing was almost full of oil. Seemed it should be empty and don't recall seeing this situation previously. It eventually drained after 15-20 minutes. The drain back valve is in place and looks normal. Can anyone please explain. Thank you.
