I just logged a regen the other day while towing my trailer. I noticed that (and I have stated this before so sorry for those who've already read it) if you dig into the go pedal too hard after a stop to get going, be it an incline you need to go up or just getting up to speed the regen can get interrupted. It usually doesn't happen unloaded but with 6K lbs of trailer it's easier to make it happen. I was on the interstate for the start of the regen and then going through hilly local roads for the rest of it.
The iDash records at 10hz, this being said each line of recorded data is 1 tenth of a second (shown in column "A") it makes for a lot of lines in a spreadsheet. I couldn't attach a XLS CFans prevented that file extension so I change the file extension to a pdf. Just download it and change it back to an XLS if you care to view it. It's a lot of lines 28K+. I highlighted in Cyan when the regen was active to make it easier to view. It really provides a ton of data for those who are data junkies such as myself.
What I recorded was 7 instances where the regen had stopped and once I was back up to whatever favorable conditions were it would restart. During this time the "distance from last regen, 715 miles" stayed at the current mileage until the last 5.8 minutes segment of regen time. Once that was finished the counter went to 0 miles "since last regen", line "19767" column "CC". In total with the interruptions the regen took 28.94 minutes. Normally it takes about 18 to 19 minutes when steady cruising and not getting interrupted. SEE column "CF" lines 19,768 thru 19,777 for details.
One thing I noted, the last column "CE" which is the "NOX Bank 1 Sensor 2" there is some erratic data in there. I'm wondering if someone else has or could record and see if they see similar data. It makes me wonder if the sensor is going south or if that's normal.
