Without an actual change?I could buy this theory, however, part numbers getting superceded is very common.
Yes, it happens.Without an actual change?
YES! possibly a supplier change but I have seen number changes for no obvious reasons.Without an actual change?
I would assume the last numbers are significant to sequential build dates and would include the effected...... But frankly thats a guess..So does this mean that the change started sometime in 2019? And how do you read VIN breakpoints?
My VIN starts 1GCPTC......, and the document indicates the breakpoint is 1GCPTB. . .. Since C is after B (the last letters I gave), does that mean mine is the newer version?
If you're not having any issues I don't see the point, particularly if the redesign is just about gurgling. Paying attention to coolant levels would give you the same protection.If indeed the tank has been redesigned, I want it.
No jerk vibes detected. If you’re a jerk, what does that make me?😦Guys, heres why Im being a jerk. Not really, but I may be perceived as a jerk.
But as of yet, I have not seen or read any hard proof that the tank has been changed.
I think this information is helpful to the Colorado community so I'm looking for real facts.
I got a picture (thank you) and I cant see any obvious external difference.
I would have to obtain two tanks to compare for full discovery. Not happening. Today.
I can think of one reason, if the tank has been strengthened in any way to reduce the possibility of air leaks, then it would be a reliability enhancement. Not saying that's it.If you're not having any issues I don't see the point, particularly if the redesign is just about gurgling. Paying attention to coolant levels would give you the same protection.
It's a pressurized system, so I doubt air leaks are an issue.I can think of one reason, if the tank has been strengthened in any way to reduce the possibility of air leaks, then it would be a reliability enhancement. Not saying that's it.
I think they can be depending on where the leak is and possibility drawing air back in at the lines to the engine or radiator instead of coolant when the system cools down.It's a pressurized system, so I doubt air leaks are an issue.
