I understand the coolant reservoir has changed for 2020-21?
Can someone post some pics from a 3.6?
Thanks
Thanks
Could be, there is an updated tank and TSB I read that helps keep air out of the system when it gets a tiny bit low.Part lookup does show a different part number for 2021. Internal baffling changed or added maybe?
I searched for it, no luck, maybe I dreamt it?Externally I don't see any obvious change.
That TSB would be helpful.
this: 19-NA-007 1..2 (nhtsa.gov)I searched for it, no luck, maybe I dreamt it?
So does this mean that the change started sometime in 2019? And how do you read VIN breakpoints?
Oooooooooooooo...... Sweeeeeet................View attachment 400091
Don’t get too excited over those curvaceous lumps, buddy. 😂
Mad skills!
I asked earlier if it's a new/replacement part number. The link below would indicate that it is. Not only does it say "replaces" but it also is the part for 2015-2020. So presumably it is a change in design.(2) The TSB don't say that the surge tank was redesigned to address a failure.
