So i work for GM and i have been looking for a cold air induction kit but i have had no luck. Does anyone have any ideas or sugestions?
How has the k&n filter been for you? I use to have a 17 z71 with cold air intake from k&n. I just traded it in for zr2.The 17 V6 engine cover has the air intake pipe cast as part of the cover. There are CAI that replace the cover and there are Air Boxes that replace the oem box and keep the engine cover. I just put a K&N in the oem box.
The S&B filters Co. Is working on it. It is a true cold air intake.So i work for GM and i have been looking for a cold air induction kit but i have had no luck. Does anyone have any ideas or sugestions?
The s&b has an included optional scoop that gets additional air from the fender holes below the coolant tank. But the 2017 version is not out yet.What I am seeing when I look at a lot of these CAIs they are drawing air from the same small fender air inlet. The K&N round filters look to have the same amount filter surface as a stock filter. I think a true CAI upgrade would involve a larger fender air inlet to provide more air for the filter to draw from with a larger scoop in the finder then install any style filter you prefer in your stock air box.
51
Just curious, what is it about the cover you don't like?Admittedly I would pay ~$200 for an intake just to get rid of the engine cover even with no gain in power.
