21 - 38 of 38 Posts
2017 Colorado
Discussion Starter #21
Just ordered a set of Falken Wildpeaks! EXCITED!!!! I'll let you knows know!
Front air dam is removed. Took about 45 minutes. Removed it and swapped orientation on two screws so they go up instead of down.
Hey, quick question. Any particular reason you removed the front air dam, or just how it looks? Do you know if that would mess with the fog lights if I were to do the same to mine? I just got a 2019 Colorado (got the coronavirus deal) and trying to educate myself on it and make some upgrades if I can, want to start small though because I don't really know what I am doing. Thanks!
2017 Colorado
Discussion Starter #24
Just for looks!
I’ll have pics of lift and tires tonight!!!!
Look forward to it. BTW: I gonna steal your list if mods so I can do them on my Colorado, seems like a good place to start. Any suggestions or ideas would be helpful as this is all pretty new to me.
Thanks!
2017 Colorado
Discussion Starter #26
Well here we are! Today was tires and level!!! I was so excited I didn't take any pics while installing, but have a before and after, and some nice afters on a little trail by the house.
And just FYI for anyone who watches a video of a level install, follow it!! Strut will come out without disconnecting tierod and control arm, but WILL NOT go back in!
Also showing the trimming I did on the waffle. No rubbing front or back. Will have caster adjusted slightly to give more clearance on the back however.
2017 Colorado
Discussion Starter #27
Also wanted to mention that the lean spacer on the front brought it level to within 1/8 of an inch side to side.
37 LF 37 1/8 RF and 36 1/2 LR and 36 5/8 RR.
2019 Colorado wt
Did I miss it but what size are your Falkens?
2019 Colorado wt
thank you!
2017 Colorado
Discussion Starter #32
Today was blackout window trim day! Pretty easy to do with a can of denatured alcohol, and plastidip. Took them off, cleaned them, sprayed then, and put them back on. Hardest part was letting them dry. LOL
4D8106FE-B4B4-4E16-9B90-6D41530BCBE8.jpeg C9DD7280-0A52-4A78-AE56-486E3811F4D1.jpeg 0B6BF629-51CA-416B-AD13-136DAC65FC42.jpeg 599B642A-EBFC-4546-8773-1749BCB3EDB1.jpeg 0B131505-2522-424E-AA65-0C8E549A4E67.jpeg 6D08DBE1-583D-4728-91E5-F1A6D8633D05.jpeg 003C1C9C-8C2E-4E32-9CA3-5357236EDBA7.jpeg 8886098B-4C32-409C-A8AD-87A74B24F31B.jpeg D0F29510-4072-428C-9478-226227CD5504.jpeg
2017 Colorado
Discussion Starter #33
Was a good weekend! Got my grill put on, my rear badge blacked out and redid my window molding. Couple questions. Removing emblems. What are some of your methods to make it easy? What products do you recommend for adhesive removal? What products do you use to keep the black trim black?
392431
392430
392433
392432
392434
392435
392436
392437
20 lb fishing line doubled over and use a “flossing” technique. A little heat from a hair dryer if it’s being tough. And Goo-Gone is your friend. I’ve heard great things about the 3M adhesive remover wheel, but I’ve never used one.
Edit: if you’re putting different emblems back on be sure to clean off the excess Goo-Gone!
2017 Colorado
Discussion Starter #35
Got the fog lights installed with the wire harness from gen5diy.com! Work like a champ!
392784
392783
392785
392786
2017 Colorado
Discussion Starter #36
Finally got my tune. Trifecta advantage+. The truck is a different machine now. How it should have been from the factory.
2017 Colorado
Discussion Starter #37
FInally got my lean spacer (leaf spring shim) and RC 1.25 body lift on today. Took about 3.5 hours for us from start to finish including the lean spacer. Didn't get great pictures but here are some. You can see it compared to my dads 77 square body in the first pic.
21 - 38 of 38 Posts
