Also should I pay for a vehicle inspection to see what was done, if it was done right and if that was the issue? Any comments, opinions and advice would be greatly appreciated
I am not sure as the second i noticed it leaking, (mind you it had been leaking for at least two days) I already had it shut off as I had drove to a job and kept it off and got it towed from there. But when i took a photo of the dash the light was on . But the truck was not turned over fully.Did the oil light come on? If not you are G2G
But looking at the whole situation and all angles, would you say it should be alright? I do have Engine warranty etc I just want some peace of mind.I am not sure as the second i noticed it leaking, (mind you it had been leaking for at least two days) I already had it shut off as I had drove to a job and kept it off and got it towed from there. But when i took a photo of the dash the light was on . But the truck was not turned over fully.
Who would do the inspection, if you decided on that? One liter of oil low, will not be a problem. They may have not filled it to the Full line at the oil change. A large spot on the concrete may not be a big leak. It has a tendancy to spread.Also should I pay for a vehicle inspection to see what was done, if it was done right and if that was the issue? Any comments, opinions and advice would be greatly appreciated
The complaint was seeing a coolant leak, and now oil on the ground. What is it?The lot where i bought it would do the inspection but due to the engine warranty i said ill just see how It goes but as of this morning 5 days after the coolant line was replaced, I'm seeing Oil spots again. So it leaves me wondering what the heck is going on! Why is it leaking again!
