All Terrain trim. Overall loved driving the truck. Handles the snow and mud better then any full sized truck.
I added 2" level kit to front and 1 extra leaf spring on back. Down side, rear brakes. Brakes wear at an excessive rate. Dealership says the brake system is working properly. 10000km at the most for set of pads. I pulled tired and now inspected pads (50%) after 6000km. Bought pads and was going to change this week. At 9000km. Washed up truck and as soon as i pulled out of wash bay heard the tell tale grind of metal on metal. Pad and rotor destroy.
3rd time this has happened in 30000km. 1000$ everytime.
So since mechanics can't find cause i started comparing brake set up on trucks doing work in my area that are not having these issues.
My guess is that the caliper has a vented top 1.5"x1" space that is scraping the mud off of rims and packing it into the space between pad and rotor. Mud acts like sand paper, destroying both. No warning of impending destruction till to late.
Truck is washed regularly and Daily brake inspections is just not feasible.
The fact that the rear brake pads have been referred to as erasers compared to full sized truck might also add to the issue.
Some say 20" rims might help.
Mud flaps can't install them. Local dealer tried it on one and the weight of the mud pulled metal on wheel wells apart.
Front driveshaft boot torn. New drive shaft is also needed. Mud flaps would haves most likely prevented this.
Wheel wells on rear of truck. Mud packs in above the liner and pushes out from inside causing a outward dent and paint cracking.
Wiring harness for stabilitrack and rear ABS hangs down below fram of truck. Without reinforcing harness with tape and rad hose the debris will eventually wear and break wire. Dealership fix this for free and reinforced it. Looks good still.
Trade in value. Horrible! Dents over wheel wells, no rear brakes and the fact that these new vehicles can now be fixed after side impact that ised to write them off, which happened to my truck at 8500km. The side impact alone dropped trade in value 7000$ ouch. 21 000$ cost to repair truck. BTW I got Tboned from a guy running stop sign.
Full sized truck is what I need.
I gave the Canyon a go and it failed for me. Just not built for the conditions.
At some point you have to throw in the towel and cut your losses.
