1 - 11 of 11 Posts
Over the past 3 days I've been struggling with an issue with my Colorado.
It says light rear turn signal error and hyperflashes
Only one head light, one parking/running light, one running light, one tail light, and one brake light seem to be working. All fog lights, dome lights, and tag lights seem to be working no problem!
I just went the Chevy dealership today believing it was the BCM (Body control module), spent $200+ and it did not solve the issue. On Monday I am going in for an electrical diagnostic but I'm also looking to save some money if anyone else has had this problem!
Any questions please ask!
Vehicle has 47,xxx+ miles and is no longer under warranty!
Link to video showing lighting errors!
Have you tried taking the bulbs out. Clean the connectors. Put dielectric grease in the connectors? that usually fixes it.
Bulb may has a poor connection or is going bad.
Sent from my SAMSUNG-SM-G891A using Tapatalk
please state exactly which lights aren't working. Your post says they are all working.
:smile2:
Discussion Starter · #4 ·
I’ve done all of the above, still nothing. I’m thinking a wire went short
Discussion Starter · #5 ·
:smile2:
One headlight, one taillight, one brake light, one parking/running light, so on so fourth. Basically only one light(s) per
Watch the video to show easier explaining
Does it do it with your fog lights off? Noticed they were LED. Might have a lack of current draw to the bcm some how. Have you changed anything else to LED?
Discussion Starter · #7 ·
It still does it regardless if the fog lights are on or off. And I just put a brand new BCM in and having the same problem.
I had my headlights 6k HIDs but I took them out and replaced the bulbs and it’s still have the same issue.
one more try, please list EXACTLY which lights aren't working and the error. You video is on the sucky side.
list left and right, ect, also, you know? exactly.
Discussion Starter · #9 ·
Drivers side head light
Passenger side running light
Drivers side brake light
Passenger running light
Drivers side reverse light
These are the lights that will not function...
I suspect you have more than one problem. The headlamp has nothing in common with the other stuff. But all the drivers rear has the same ground and ground wire. Pull out the rear lamp assembly and check out the connector/s and wiring from the tail lamp assembly to the ground. It is a black wire. The book says it is here:
Under vehicle, outboard of left frame rail, forward of the left leaf spring mount
start there and see what happens. One thing at a time.
so you have checked/replaced all of these bulbs, correct? look very closely at the contacts/wires. A good visual inspection is always the first place to start.
Discussion Starter · #11 ·
I checked all bulbs, but when I get it back on a lift I’ll be sure to check the connections with my test light
1 - 11 of 11 Posts
