1 - 8 of 8 Posts
I have seen the tutorials and many people swap out their gauges for different LEDs and just wanted to get some things cleared up before going into this whole thing:
-How hard is it to take off the needles and put them back in the right position? This is really my main concern. Don't want to break the needles or put them back in the wrong position and having it say I have 1/4 tank of gas when I really have 1/8 or something like that.
-I've heard needles from Hummer H3's fit in place of the orange needle and then you can change the color of those from the LEDs, is that correct?
-In a 2008, would the LEDs be through hole or SMT?
-To remove the cluster can you just pry off the trim around it or do you have to take off more of the dash?
Lastly, anybody have an old set of gauges they're willing to part with? I'd like to have one to practice on and experiment with different color combos.
Thanks!
Super Moderator
The trim around the gauges just pulls off. Just keep an eye on the metal clips.
H3 needles should fit... I used some white needles I found on ebay.
Needles are pretty easy to take off just use a fork or something to pry up on them
Super Moderator
Pictures are gone in this one becuae of photobucket crap but it's pretty descriptive https://www.355nation.net/forum/how-interior/7408-how-remove-cluster.html
How to recalibrate the needles is explained in a couple of the tutorials above. Take a pic of the gas gauge before removal so when you recalibrate it you know where it's supposed to be when you test it after installing new needles. Make sure engine is cold so the temp gauge is zeroed out when you remove that needle
Super Moderator
Any chance you know if the LEDs are SMD or through hole? I know you said you had a local guy do it but just curious if you know
3mm through hole
As pictured in the how to I pasted above... and below
1 - 8 of 8 Posts
