I STILL have the goddamn ABS fault on the dash and my speedo doesn't work after replacing both hubs with high quality Moog hubs. About 5 years ago I had the ABS fault light come on and I traced it down to the passenger side hub which I replaced and it got rid of the problem for 5 years. This time I just replaced both since I was in there but the light has not gone away. I did the passenger side first, drove it for a while, light didn't go away. Then I hooked up my ABS code scanner and the scanner said front left ABS circuit so I figured, sweet it's the driver's side hub so I replaced that but goddamnit the ABS light is STILL on and my speedo still doesn't work. UGH. Luckily it's a manual shift truck otherwise I'm sure the trans wouldn't shift right. No engine codes whatsoever.
