1 - 2 of 2 Posts
I have a 2004 Colorado w/4 wheel drive. The TCCM is not working and I think I know which component failed. I was wondering if someone has a schematic of the TCCM so I can verify I am replacing the correct part.
there ae 2 modules, one on the front axles and one on the transfer case. You can use a volt meter or crawl under and listen when some one pushes the button to see if you hear either one click/activates. or disconnect on and see if you hear the other one activate
I googled and there are pictures of schematcis for the tccm wiring,
1 - 2 of 2 Posts
