2004 Colorado rear differential HELP
837 Views 4 Replies 2 Participants Last post by  Carter04
So I went to change out my rear differential oil and the fill plug is in so tight that it stripped the plug. I was wondering if anyone thinks its a good idea to drill out the plug and retap it with a slightly bigger size plug or if someone could find a cover with a fill bolt for relatively cheap ( I don't want any of the over $200 performance ones ). If anyone has any other ideas that isn't drilling it out with a new plug or the new cover I would love to hear them. I am telling you that bolt would not come out even with an easy out, heat, a breaker bar, and a lot of penetrating fluid. I am trying to not break the bank. The differential cover would need to fit the gm 10 bolt 8.0" ring gear differential. It is from my 2004 Colorado z71 4x4 package
1 - 5 of 5 Posts
Easiest method is picking up a new one. This one comes with a new gasket and bolts. Not a bad deal really.
That would be fine but I am needing one with a fill bolt in it
Sorry. Didn’t realize it didn’t have a fill bolt. My mistake.
its fine. thanks for trying to help
1 - 5 of 5 Posts
