Sway bar links are common to loosen up for sure. I’d check to make sure they are tight before replacing them.
The control arms aren’t really known to fail but the upper control arm bushings are pretty much junk from the factory.
Sway bar links are common to loosen up for sure. I’d check to make sure they are tight before replacing them.Do the sway bar links go on these things often? Or more likely control arms?
