1 - 5 of 5 Posts
If i remove my cat in a 2008 what will be different from stock
and what are my options with the sensor
what other difficulties will i expierience?
Check out the "how to" thread further down the performace forum. It has all the info u need. your 08 will be the same as the 07. You can either relocate the 02 sensor, or send your pcm out to pcmforless and have them disable that 02 sensor. [/url]
I know what you mean. If you feel that you can gut your cat, go for it. Your best bet is to do what im going to do and send your pcm out to pcmforless.com and have them tune it and disable the 02 sensor so your pcm does not throw a code after you gut the manifold cat.
1 - 5 of 5 Posts
