1 - 1 of 1 Posts
Hello everybody.
I have a 2005 Colorado 4x4 with 98,000 miles. It needed new brake pads on the front so they were changed. It has a showed an ABS and brake light and the brakes on the front will lock up ever since. The ABS isn't working either. I have checked the brake lines, and fuse. I have replaced the master cylinder, the ABS module, brake booster, the front passenger side wheel speed sensor (3 times) and the complete hub assembly (3 times), the brake caliper. It still has the same issue and will not work. The computer always says it is a wheel speed Issue on the front passenger. I’ve had two different mechanics say it is the wheel speed sensor and they change it but it doesn’t fix the truck. I am at a loss. Does anybody know the secret to fixing this issue?
1 - 1 of 1 Posts
