I4 Manual engine issues - Chevy Colorado & GMC Canyon
 4Likes
  • 1 Post By DFlorida
  • 1 Post By Crazyjack177
post #1 of 14 (permalink) Old 04-13-2019, 04:57 PM Thread Starter
Hi, new here. Ive been scouring the internet for some information. I have a 2008 Colorado, 2.9 I4 WT manual that I have 73000 miles on. Recently when I start it it will make a noise kind of like metal hitting metal. It only happens for literally one or two seconds when I start then goes away. And it's not everytime. Also it doesn't matter if it's cold or warm outside, or if I cold start it or it's been running for some time. It's not a grinding so it's not the starter sticking. It's like a weird knocking noise, but it's not the same sound as rods knocking. Also, the rpms start at around 1100 and will fluctuate up and down until it's around 750-800. I don't know if that's normal or not. Of course today it hasn't been doing it. Also if I rev it up to about 2500-3000 and let off, it'll sound kind of like it's backfiring in the exhaust. I'm honestly stumped on what it is. I know when I first got it I had to replace the vvt sensor because it was causing it to die when the rpms fluctuated too much (up until it decided it wanted to vary the rpms at idle at a swing of almost 800rpms) When I can I've been video recording every start up and when I can catch it I'll post a video, but does anyone have any ideas? Thanks!
Crazyjack177 is offline
post #2 of 14 (permalink) Old 04-13-2019, 07:59 PM
the RMPS should not fluctuate should go to around 1200 cold then slowly drop to 650-700 , Has the Cat been Gutted from the Exhaust Manifold ?
DFlorida is online now
post #3 of 14 (permalink) Old 04-14-2019, 12:31 AM Thread Starter
No I don't think so. I haven't looked at that, but it normally sounds stock. I've only had it a year and I haven't done anything yet because the previous owner was an older guy who barely drove it. I mean it had only 65000 miles in 10 years so 😕 So theres nothing besides tint and a sunshade the previous owner put on because they were snow birds who who lived in Arizona, so the tint I'm guessing is for the sun in AZ. (Never been but I'm going to take an educated guess 😆)
post #4 of 14 (permalink) Old 04-14-2019, 01:42 AM
I have seen the cat itself break in half & make a intermittent ratting noise when engine is at high rpms , You can remove the 02 sensor in the Exhaust manifold & should see the top of the cat make sure its there and in one piece
16WhiteColly likes this.
post #5 of 14 (permalink) Old 04-14-2019, 01:39 PM Thread Starter
Yeah, well I can check that. It's hard to hear, but you can very faintly make out the noise at the very beginning. Of course when I'm trying to capture video it's not doing it as aggressively XD
https://photos.app.goo.gl/zY2FKgLoK1m4T7sK8
post #6 of 14 (permalink) Old 04-14-2019, 06:59 PM
Can you kind of pin point where the noise is coming from top of engine driver side or pass side or bottom of engine The cat rattle will come from lower pass side of engine best heard from pass side wheel well .
post #7 of 14 (permalink) Old 04-14-2019, 07:05 PM Thread Starter
https://photos.app.goo.gl/NsWvdmfzfqiDL3eG6
Here's a good one finally. And no it's coming from more up top. I've had bad cats and other exhaust issues on other vehicles before and it's definitely not that. Unfortunately I don't have anyone that can help with starting it when I need it so I'm just playing by ear from the driver's seat:/
post #8 of 14 (permalink) Old 04-15-2019, 05:01 AM
White016's Avatar
Sounds like a VVT gear assembly (don't know the real name off hand) on a Toyota. It sits on the end of the exhaust cam IIRC. The timing chain turns it. A very common thing on them. They have a pin that locks it in place until the oil pressure comes up. The problem is they eat the pin and rattles just like that for a second or two until oil pressurizes it.
I'm thinking your 4 banger has something just like the Toyota's from the sound of it. Sounds really bad when you first start it! Like a rod or piston will come out the side of the block any second. Then all of a sudden the oil pressure comes up and then it's quiet as a mouse. Kind of like worse than a lifter but not as bad as a rod sort of noise.
White016 is offline
post #9 of 14 (permalink) Old 04-15-2019, 12:23 PM Thread Starter
That's what I was thinking, either that or the timing chain tensioners or something. But I did have to swap out the vvt sensor because it was so mucked up with sludge it decided to not run. I think the previous owner didn't keep up with the oil changes. I'm going to go get it looked at here in the next few weeks anyway, since I currently don't have a garage, but I wanted to know what it was approximately so I knew what to say XD
White016 likes this.
post #10 of 14 (permalink) Old 04-15-2019, 12:25 PM Thread Starter
And yeah, after a second or so it's super quiet. Like a brand new truck \_(ツ)_/
post #11 of 14 (permalink) Old 04-16-2019, 12:54 AM
White016's Avatar
This thing right here:
https://www.rockauto.com/en/catalog/...sprocket,18586
It even looks like the Toyota's. I bet that is the culprit.
White016 is offline
post #12 of 14 (permalink) Old 04-16-2019, 02:54 AM
I Personally Don't think its going to be the Exhaust Cam Actuator especially with only 73k miles , the VVT is a solenoid operated Valve ( not a sensor) that at higher Rpms & Speed the ECM applies voltage to solenoid to open the valve to apply oil pressure to the Exhaust Cam Actuator to push the locking pin backwards to free the actuator to advance the exhaust cam timing , it almost sounds like you have what we Mechanic's call a dry oil start , the oil in the oil passages in the engine is draining out overnight & when you start the engine in the morning you have a rattle for just a few seconds until the oil pressure fills the passages & then everything is quiet .
post #13 of 14 (permalink) Old Yesterday, 07:25 PM Thread Starter
Yeah. It's just really annoying, but I plan on pulling the top off this week and check everything out. -_-
post #14 of 14 (permalink) Old Today, 03:54 AM
Before i would start tearing into the engine First try a new oil filter the anti-drain back valve in your filter could be leaking and over night letting the oil drain out of the oil passages I Recommend the Purolator One PL14006 oil filter Never had one leak .
Similar Threads
2016 Diesel Colorado Consuming Oil jagster936 Diesel 107 12-30-2018 06:49 PM
GMC Canyon Manual Transmission Review (thorough) LAGMC71 2nd Gen Chevy Colorado Reviews / 2015 GMC Canyon Reviews 5 04-30-2018 03:11 PM
Engine Wiring Harness Issues CitadelSean Technical Questions / Tips / How To 3 06-09-2017 02:48 AM
Chevrolet : Colorado 2WD Ext Cab 128.3" WT Chevrolet Colorado 2WD Ext Cab 128.3" WT N Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 03-04-2015 12:00 PM
Chevrolet : Colorado 2WD Ext Cab 128.3" 2 wd ext cab 128.3 new 2 dr truck manual gaso Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 01-16-2015 01:00 PM
