589fab Skid Plate Support Bracket - Chevy Colorado & GMC Canyon
 24Likes
post #1 of 31 (permalink) Old 04-14-2019, 01:49 AM Thread Starter
ZedArgh2's Avatar
Anyone have hands on or details with this yet?
https://589fab.com/collections/armor...upport-bracket
2018 Chevy Colorado ZR2 CCSB| Graphite Metallic | 2.8L Duramax Diesel | Bose | Nav
  • Mods: 589Fab HD Shock Skids
ZedArgh2 is offline
post #2 of 31 (permalink) Old 04-14-2019, 10:21 AM
JBurg540's Avatar
Will post my thoughts as I ordered a powder coated bracket and will be picking it up in person later this week. Looking forward to meeting the 589 Fab guys!
From the pictures the design will transfer any forward to rear (or vice versa) force from a skid plate impact to the cross frame beam. This is done due to the sides of the bracket having a u-shape that fits on both sides of the cross frame beam.
I believe the screen shot of the bent Colorado OEM skid plate mounting bracket is from this forum. Glad to have a ready made solution for only $100.
[email protected] likes this.
JBurg540 is offline
post #3 of 31 (permalink) Old 04-14-2019, 12:11 PM Thread Starter
ZedArgh2's Avatar
It looks legit. Iím curious how it integrates with different sets of skid plates, I assume it would work with all.
ZedArgh2 is offline
post #4 of 31 (permalink) Old 04-14-2019, 01:00 PM
ssm1tty's Avatar
I opted for the bare metal version so I would receive it faster. Prepped, painted, and installed with my factory zr2 front skid and steel superskidz. The only issue was it was a tight fit because of all the layers of primer/paint. There was about a 3/4 inch gap left after muscling it on which had me concerned. I ended up using the supplied bolts to walk it in. Alternating between bolts, essentially pressing it in...it's NOT coming off! No clearance issues, the little legs don't interfere with any of the power steering bolts heads.
ZedArgh2 and JBurg540 like this.
2017 ZR2 3.6L, 33s, 1.5 BL, diesel springs, GM cai, Mallet full exhaust, Relentless Fab bumpers & rack, Nitro 4.56 gears, Trifecta tuned.
https://www.instagram.com/ssm1tty/
ssm1tty is offline
post #5 of 31 (permalink) Old 04-15-2019, 12:48 AM Thread Starter
ZedArgh2's Avatar
Excellent info, thanks for sharing.
ZedArgh2 is offline
post #6 of 31 (permalink) Old 04-15-2019, 10:44 AM
maxwell_hau5_caffy's Avatar
One thing to note.
For those wanting this product, You'll need to make sure you didnt previously bend the bracket as this support bolts onto it. If you have bent the OE mount, you'll have to bend it back into the position which is a lot more difficult than you may think and by that point just cut it off.
If thats the case, it may be worth cutting it off and putting a piece of boxed steel with a few layers of metal on top to give the screws to bite into it.
@supermodulation gave me these measurements, so if you decide to make you're own, just make sure its at least this deep from the bottom of the crossmember, 2.30"
For the life of me, I can't find any pictures that I took of the actual mount, but it was a 2" piece of boxed steel, and the parts where the bolt will go in, was threaded and had 2 layers of 1/4" steel welded to give the bolts more metal to grab.
2016 Black Colorado Z71 4x4
Too many mod's to list. Check out the build thread for more info
Click here for my build thread
Instagram: @trukstuf
maxwell_hau5_caffy is offline
post #7 of 31 (permalink) Old 04-15-2019, 12:22 PM
Dan@589FAB's Avatar
As long as they use the factory 3 holes on that skid support bracket, it should work with all skid plates!
Originally Posted by maxwell_hau5_caffy View Post
One thing to note.
For those wanting this product, You'll need to make sure you didnt previously bend the bracket as this support bolts onto it. If you have bent the OE mount, you'll have to bend it back into the position which is a lot more difficult than you may think and by that point.
You could also cut the OE bracket off, and weld this bracket in it's place after having some nuts welded over the holes.
2018 ZR2 with a bunch of goodies
589 Fabrication
www.589fab.com
[email protected]
Save 5% using code CFANS5
post #8 of 31 (permalink) Old 04-15-2019, 12:38 PM
So this just goes under the skid plates and prevents the stock bracket from bending? Crazy that the stock one bent like that. That's a poor design.
BizzyB is offline
post #9 of 31 (permalink) Old 04-15-2019, 12:44 PM
Dan@589FAB's Avatar
The design could be beefed up some, but the biggest issue is the thickness of the material on a bracket as critical as this one. The pictures I've included will give you an idea. It mounts over the factory bracket. Basically you are putting this bracket between the factory bracket and your skid plates. It really stiffens up the mount!
File Type: jpg 7aac9f2d7b6d9cc0b4c3a94f8d77e19a_1024x1024.jpg (35.1 KB, 35 views)
589 Fabrication
www.589fab.com
[email protected]
post #10 of 31 (permalink) Old 04-15-2019, 03:03 PM
Random question, if the skid plates use those mounting holes, how do you keep that thing on when you're putting your skid plates on?
scoobydrew32 likes this.
BizzyB is offline
post #11 of 31 (permalink) Old 04-15-2019, 04:52 PM
Dan@589FAB's Avatar
Good question!
It's a pretty snug fit once it's up there! I was able to reinstall my skids without worry of it falling.
madcratebuilder and BizzyB like this.
589 Fabrication
www.589fab.com
[email protected]
post #12 of 31 (permalink) Old 04-15-2019, 04:57 PM
Can you repost? Your pics arenít showing up
2016 4x4 Ext cab All Terrain Canyon
Cyber grey metallic
Tow package
Superskidz #1-4
2" RC level, AS dif drop
Westin HDX drop steps
Pedal Commander, Curt Triflex brake controller
Line-X, BAKFlip MX4
589 HD Shock Skids
Prothane end links, Sway bar drop kit
STEDI H11 LED Copper Head low beams
STEDI ST3K 31.5Ē LED light bar
thegraham77 is offline
post #13 of 31 (permalink) Old 04-15-2019, 05:14 PM
madcratebuilder's Avatar
I'm waiting on a brown truck to drop mine off, can't wait to beat it on.
2017 Colorado ZR2 Deepwood Green Metallic, Ext Cab 3.6 DI DOHC V6 (LGZ) 8-speed auto (8L45).
Midwest Overland Ind, 589 Fab, Warn, GMPP, Trifecta, Nitro Gear, Rhino Rack, Wilco Offset, Smittybilt, Ultra Ranger. Supermod Skidz.
Illegitimi non carborundum
madcratebuilder is offline
post #14 of 31 (permalink) Old 04-15-2019, 05:35 PM Thread Starter
ZedArgh2's Avatar
Bare or power coat?
ZedArgh2 is offline
post #15 of 31 (permalink) Old 04-15-2019, 06:18 PM
I think I went with powder coat but really don't remember.
post #16 of 31 (permalink) Old 04-15-2019, 10:48 PM
Site Sponsor
Chris@RealTruck's Avatar
Yeah I'm gonna go ahead and get one of these! Might throw a few spot welds on it while I'm installing
maxwell_hau5_caffy likes this.
Truck: 2016 CC Duramax 4x4 / Decked / Bull Rings / Husky / BMS / Icon / Deaver / Method / BFG / Smittybilt / Factor 55 / Cobra / Firestik / Midland / Chassis Unlimited / SuperSkidz / AFE / Hackman / AEV
Forum members save at RealTruck! PM for info.
Visit: RealTruck.com / Instagram / Facebook
post #17 of 31 (permalink) Old 04-16-2019, 09:17 AM
Don't do that, it would make too much sense
Sent from my Pixel 2 using Tapatalk
NEVER GIVE UP
Never stop trying to exceed your limits, God knows we need the entertainment.
medic535 is offline
post #18 of 31 (permalink) Old 04-16-2019, 10:31 AM
Good question!
I ordered mine today. Gonna get it fitted before I pickup some skid plates. Hope you guys are churning em out quickly!
BizzyB is offline
post #19 of 31 (permalink) Old 04-16-2019, 11:25 AM
Another solution as well. Would be tricky painting the inside after welding though.
I just wish this was out before I bent mine early 2017. :(
Very carefully.
post #20 of 31 (permalink) Old 04-16-2019, 09:27 PM
Dan@589FAB's Avatar
It'll get picked up in the morning!
I wish we had already been in business at that time! We may have had it then! You beat us by a couple months.
BizzyB likes this.
589 Fabrication
www.589fab.com
[email protected]
Similar Threads
Preliminary ZR2 Bison Part Numbers emulous74 2nd Gen Chevrolet Colorado Forum / 2015 GMC Canyon Forum 56 04-05-2019 10:08 AM
Official 589FAB Skid Plate Group Buy Thread [email protected] For Sale - WTB - Business Sales 100 10-14-2018 12:23 PM
FALSE ADVERTISING - Z71 4x4 Skid Aluminum Skid Plate Joe K. General Truck Chat 179 10-14-2004 11:06 PM
Skid plate news Earthspirit60 General Truck Chat 7 04-19-2004 10:37 PM
skid plate brink General Truck Chat 12 03-24-2004 02:05 PM
