What do your diesel fuel injectors look like? - Chevy Colorado & GMC Canyon
 4Likes
  • 1 Post By DieselDrax
  • 1 Post By lqdchkn
post #1 of 13 (permalink) Old 04-11-2019, 01:02 PM Thread Starter
My truck has 353 miles on it (as in, I've never even filled the tank yet!). These fuel injectors seem way more fouled than I would expect that soon (see attached photo).
Anyone else have photos of their fuel injectors? If so, can you share with the number of miles the vehicle had (and the reason you had them out)?
Thanks!
julie
P.S. I'm expecting the dealer to say "that's normal", but I think foreign material got in the cylinder and made for some dirty burning.
joolie is offline
post #2 of 13 (permalink) Old 04-11-2019, 01:13 PM
DieselDrax's Avatar
Diesel is dirty/sooty when burned so I wouldn't read too much into how they look.
Assuming they pulled them so they could check for any cylinder damage from your turbo failure by using a borescope?
tcoilburner likes this.
DieselDrax is online now
post #3 of 13 (permalink) Old 04-11-2019, 05:43 PM Thread Starter
Yes, that's why they pulled them. But the scope was too big to fit and so they couldn't actually see anything with it.
It just seems if they're that dirty after 3000 miles, how must they look after 30,000?!
joolie is offline
post #4 of 13 (permalink) Old 04-11-2019, 05:54 PM
DieselDrax's Avatar
Doh, that's too bad.
Ah, seems like you're assuming this is a cumulative thing that is going to keep building over time and eventually turn into a giant mess. That's not going to happen. Remember, diesel is an oil whereas gasoline is a solvent. Soot is going to happen, injectors aren't going to stay shiny and clean. With such low miles on your engine you haven't really had a chance to let the engine work, get the temps up, etc. Idling, low speeds, low loads will cause more soot than working the engine well. You have low miles and are still within the break-in period so you're not expected to work the truck hard yet.
But once you get some miles on it then work it. Get the cylinder temps up, give it good throttle when getting on the freeway. That will help burn off the soot and keep the engine happy.
I wouldn't give it a second thought at this point.
joolie likes this.
post #5 of 13 (permalink) Old 04-11-2019, 05:55 PM
30,000 is also your fuel pressure in PSI. The resulting flow out of the nozzles will keep the injectors clean where it matters.
Chuck_B is offline
post #6 of 13 (permalink) Old 04-13-2019, 02:47 AM
What made you check them at such low miles, to see what?
I DID IT is offline
post #7 of 13 (permalink) Old 04-13-2019, 10:34 AM
I believe this is the poster that had a major engine issue, so this is just part of that.
Goodspike is offline
post #8 of 13 (permalink) Old 04-13-2019, 12:23 PM
DieselDrax's Avatar
That was mentioned in this thread that literally only had 5 posts before yours. Please read the entire thread before replying.
Troutbum1971 likes this.
post #9 of 13 (permalink) Old 04-13-2019, 02:22 PM
Thanks!
julie
Diesel are dirty but not to that extent, what you see there is what the EGR system does to our new modern diesel which kills these engines. I would think since you had a blown turbo that you were not getting a good burn in your combustion chamber which would also create additional deposits. Run a good diesel fuel additive like Bestline, Stanadyne or Diesel Kleen (gray bottle for summer and white for winter) to help cut some of that crud and if you don't give a crap about your warranty do a full DPF and EGR delete and extend your engines life and increase its performance.
XFordFanboy is offline
post #10 of 13 (permalink) Old 04-13-2019, 02:34 PM
One of mine, looks blown up
2016 Z71 Baby D
Troutbum1971 is offline
post #11 of 13 (permalink) Old 04-14-2019, 06:16 AM
Okay thanks
I DID IT is offline
post #12 of 13 (permalink) Old 04-14-2019, 05:31 PM
Moderator
Cleaned up some whining
@I DID IT Ask a stupid question get a stupid answer, welcome to the internet
DieselDrax likes this.
lqdchkn is offline
post #13 of 13 (permalink) Old 04-14-2019, 10:46 PM Thread Starter
That makes sense.
DieselDrax also reminded me that the engine wasn't even through the break-in period.
joolie is offline
Similar Threads
Does diesel fuel always cost more than gas in the U.S.? 404 Not Found Diesel 32 08-02-2016 04:41 PM
Is the diesel right for me? zacparry Diesel 32 02-06-2016 11:35 PM
Partial List of OBD II Automotive Diagnostic Trouble Codes max_headroom Technical Questions / Tips / How To 23 05-09-2014 09:53 PM
fuel injectors Bud General Truck Chat 2 09-02-2007 08:39 AM
Chrysler to roll out diesel Cherokee YellowSportZQ8 General Off Topic 1 14 06-02-2006 03:12 AM
