Rear Lamp Bulb Replacement with LEDís - Chevy Colorado & GMC Canyon
 9Likes
post #1 of 22 (permalink) Old 04-12-2019, 01:16 AM Thread Starter
Had my rear lamp lenses smoked with tinted clear coat, but they didnít come out dark enough.
Before I go darker, however, Iíd like to up the brightness of the rear bulbs.
Picked up Sylvania 7443 ZEVO LED Bulbs: https://www.oreillyauto.com/detail/b.../4743393?pos=1
But when installed into the lamps, they werenít any brighter than stock!?
Anyone have any suggestions on what bulbs I should use behind a tinted rear lamps?
Thank you.
dbs600 is offline
post #2 of 22 (permalink) Old 04-12-2019, 08:31 AM
Thread moved to the lighting and electrical section.
Please post in the proper sub sections of the forum
Toughsox likes this.
2011 Colorado CC Z71 2LT 4X4 3.7L with a few mods.
GregDAP is offline
post #3 of 22 (permalink) Old 04-12-2019, 08:38 AM
Thank you.
Something with a lot more LED's with rear and side firing for more lumens, like these: https://www.diodedynamics.com/turn-t...rado-four.html
and you are going to need to add resistors for each bulb (4) to quell hyper flashing, and burnt bulb dash warnings.
Also, get red LED's, unless you like pink tail lights.
2017 Z71 CCSB, V6, Brownstone Metallic
2017 LT CCSB, V6, Cyber Grey Metallic *TRADED*
2015 Z71 Ext Cab, V6, Red Hot *TRADED*
post #4 of 22 (permalink) Old 04-12-2019, 10:27 PM
Nice to see that they're offering them in sets now.
I would pull the trigger on these if the running lights were stock lumens with the brakes being XP80 brake light brightness.
2015 silver Z-71 CC, SB, V6, tow, Bose/nav.
JeffC is offline
post #5 of 22 (permalink) Old 04-13-2019, 12:06 AM
BudRacing's Avatar
A word of caution: LEDs often introduce interference with the backup cam.
Toughsox and MaineMan like this.
2019 Colorado CCSB Z71 2wd
BudRacing is offline
post #6 of 22 (permalink) Old 04-13-2019, 08:00 AM
These are much brighter than stock. Did the same in the rear cargo light in the 3rd brake light, much better.
streak07 is offline
post #7 of 22 (permalink) Old 04-13-2019, 08:10 AM
Iceman62's Avatar
IMO, you get what you pay for so...go big, or go home w/LED upgrades. If/when I do the tails, picking either Diode Dynamics, or vLEDs. Either way you'll need resistors & those cheap auto store bulbs aren't a good solution. Tried installing in my '06 355 & couldn't get them to work right...resistors & all sucked. Good luck & let us know what you end up purchasing/installing.
The "Iceman" Cometh
MSGT, USAF (Retired)
18 Colorado LT Redline 4X4 Crew (Silver/Ice-Ice Baby)
Born in the US of A!
Iceman62 is offline
post #8 of 22 (permalink) Old 04-15-2019, 04:53 PM Thread Starter
Thank you very much everyone!
$80 isn't bad, but wow, not cheap for the XP80's ($180!), which have the highest lumens. Ugh.
How many lumens do our stock bulbs have?
Wondering whether or not the XP48's are worth it. :/
Their site is also unclear whether or not free shipping to you and free shipping for returns, need be.
Going to e-mail them to ask.
dbs600 is offline
post #9 of 22 (permalink) Old 04-15-2019, 05:03 PM
I just installed HP11 (310 lumens) from Diode Dynamics, they are slight brighter than stock and the XP80's are 510 lumens which is almost double stock. I know you said your tails are tinted. You really don't want to go much brighter because folks will think you are on your brakes when you are not, or think you have a rear fog light. Diode Dynamics has a 30 day return policy, so get the HP11's and the XP80's and try them out and return the ones you don't want.
'19 ZR2 Bison EC Diesel
#IWorkForGM-IT Business Analyst
emulous74 is offline
post #10 of 22 (permalink) Old 04-16-2019, 12:15 AM Thread Starter
Thank you very much!
Did you purchase / install the resistors as well, or not necessary in our trucks?
dbs600 is offline
post #11 of 22 (permalink) Old 04-16-2019, 10:00 AM
I installed 4 resistors, they are definitely needed for our trucks, unless you are willing to put up with the light bulb out messages in the DIC
Thanks to this post: https://www.coloradofans.com/forums/...il-lights.html I followed the wiring diagram and it made it very easy.
post #12 of 22 (permalink) Old 04-16-2019, 11:48 AM
i installed some ebay special on my truck.....I looked for the ones with the most led attached, and at least said the most lumens.....prolly not the best out there, but they are better then stock....and require no extra work other then plugging them in
Koda2831 is offline
post #13 of 22 (permalink) Old 04-18-2019, 02:23 PM
Twan's Avatar
I picked up a set of the harnesses with the resistors wired in from GEN5DIY when I converted to LED so I didn't have to modify anything and they've been working fine so far. https://www.gen5diy.com/collections/...t-load-harness
Twan is offline
post #14 of 22 (permalink) Old 04-18-2019, 08:29 PM
Toughsox's Avatar
My entire truck is wired with LEDs and I never noticed this. All mine came from superbrightleds.com.
:shrugs:
wrankin and BudRacing like this.
Toughsox is offline
post #15 of 22 (permalink) Old 04-19-2019, 01:49 PM
BudRacing's Avatar
Good to know. I was hoping someone would chime in to say that theirs had not done so.
post #16 of 22 (permalink) Old 04-19-2019, 02:27 PM
:shrugs:
I had not heard of this issue. My LEDs have worked fine.
Bill
2018 GMC Canyon Denali Crew Cab 4WD V6
2016 Chevy Camaro 2SS
2015 GMC Canyon SLT Crew Cab 4WD (sold)
2004 Chevy Colorado Z71 Crew Cab 4WD (sold)
1970 1/2 Chevy Camaro Z28 (sold many years ago)
wrankin is online now
post #17 of 22 (permalink) Old 04-19-2019, 03:12 PM
My guess is it might be a short in the backup cam wiring. I donít have this problem and Iíve never heard of it before with either.
post #18 of 22 (permalink) Old 04-19-2019, 09:58 PM
Toughsox's Avatar
At the same time though, there are literally hundreds of companies making bulbs so, I have to imagine many are just fly by night operations ( I didnt say Chinese knock offs, did I? ) But its not hard to imagine some companies might be using sub-standard quality parts which could induce problems.
If you may recall, GM stated LED bulbs were the cause for some of their random airbag deployments.
Toughsox is offline
post #19 of 22 (permalink) Old 04-19-2019, 10:57 PM
BudRacing's Avatar
https://reductionrevolution.com.au/b...ference-emf-rf
post #20 of 22 (permalink) Old Yesterday, 04:31 PM
One would think that by now you could get led bulbs with built in resistors. I honestly cannot think of a vehicle that wouldn't hyperflash without them. Either that, or allow us to turn off the load sensor.
2017 Colorado Z71 CCLB -Graphite
Morimoto 2stroke 2.0 H11's
Sealight 9005's
Extang Encore tonneau
weasel1 is online now
Similar Threads
Chevrolet : Colorado Crew Cab 126.0" WB 1SE LS Z71 Crew Cab 126.0" WB 1SE LS Z71 4 dr Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 07-21-2015 03:10 PM
Chevrolet : Colorado 2WD Crew Cab LT w/2LT Chevrolet Colorado 2WD Crew Cab LT w/2LT L Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 05-25-2015 08:00 PM
Chevrolet : Colorado 2WD Ext Cab 128.3" LT Chevrolet Colorado 2WD Ext Cab 128.3" LT N Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 02-26-2015 09:00 PM
Chevrolet : Colorado Crew Cab Z71 4wd NEW*4x4*remote start*spray bedliner*heated seat Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 02-20-2015 08:00 PM
Chevrolet : Colorado 2WD Ext Cab 128.3" LT Chevrolet Colorado 2WD Ext Cab 128.3" LT N Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 02-18-2015 03:00 PM
