How to: Power Tailgate Lock - Chevy Colorado & GMC Canyon
 114Likes
post #1 of 203 (permalink) Old 05-16-2015, 09:57 PM Thread Starter
I used the Pop & lock kit PL8140, found here:
1. Remove the tailgate lock panel cover using hex bit
2. Remove retainer clip on top of the OEM cam. Use a small screwdriver to pull up the tiny tab on the retainer clip, then slide the clip off. Remove the OEM cam.
3. Replace original cam with cam from pop-lock, and secure with pop-lock retainer clip
4. Mount pop-lock unit by removing the bolt on the right and then replacing once pop-lock actuator is installed
5. Run wire from under tailgate to the pop-lock unit
6. Run the wire down the truck frame rail
7. Remove the driver side sill panel by pulling up on the edges and then rotate out/up
8. Drill 1/4 hole into plastic cover under driver foot well
9. Pull wire through and insert wire into wire tray at the front
10. Find the larger solid gray wire, and the larger tan with yellow stripe wire
11. Use red crimp connectors to join the pop-lock blue wire to the solid grey wire, and the pop-lock green wire to the tan/yellow stripe wire. Note: tan/yellow may appear tan/green-ish due to lighting conditions.
12. Test locking/unlocking to verify expected results
If any questions you can refer to this video, or ask me questions. Enjoy!
Edit: Corrected step 11 to reference tan/yellow wire instead of tan/green.
2015 Red Hot Colorado CC, Short Bed, Z71 4x4, Nav/Bose. Mods: Tailgate Lock | Hardwire Dashcam | Bakflip VP Cover | OEM Bed Extender
LED Interior, Bed and Reverse Lights | 4x4 Switch Protector | Modified Air Dam | LED Light Bar | Auto Springs 2" Level kit | Stubby Antenna | Black Exhaust Tip
enigy is offline
post #2 of 203 (permalink) Old 05-16-2015, 09:58 PM Thread Starter
Here's what the kit comes with. I found that I needed about 15 more zip ties then what they provided. So make sure to grab those before you start.
AMorton and DasGoob like this.
enigy is offline
post #3 of 203 (permalink) Old 05-16-2015, 10:50 PM
col_ed's Avatar
Man I think I just found the next thing I want to put on my truck... Didn't realize this existed in the aftermarket.
I see that you used the one for the Silverado / Sierra. Is there any fitment issues when you put the cover plate back?
16WhiteColly likes this.
col_ed is offline
post #4 of 203 (permalink) Old 05-16-2015, 11:45 PM
hpfontenot's Avatar
Well written. My install was exactly the same as yours.
No fitment issues at all. Pop & Lock verified this as well.
16WhiteColly and Coloradoh like this.
hpfontenot is offline
post #5 of 203 (permalink) Old 05-17-2015, 01:14 AM
TexazReece's Avatar
Thank You for this great write up. My mod list just keeps getting longer lol.
TexazReece is offline
post #6 of 203 (permalink) Old 05-17-2015, 08:31 AM
Sweet! Thanks for the how-to write up.
2017 Z71 CCSB, V6, Brownstone Metallic
2017 LT CCSB, V6, Cyber Grey Metallic *TRADED*
2015 Z71 Ext Cab, V6, Red Hot *TRADED*
post #7 of 203 (permalink) Old 05-17-2015, 03:26 PM
TexazReece's Avatar
I don"t think this could be done if someone had the spray in bedliner?
post #8 of 203 (permalink) Old 05-17-2015, 03:44 PM
hpfontenot's Avatar
If they sprayed over the rear panel you would have to cut around it to remove it. Mine has a spray in liner, but the installer removed the panel and sprayed it separately so that it was easily removable.
Kane Martin and 16WhiteColly like this.
post #9 of 203 (permalink) Old 05-17-2015, 03:55 PM
TexazReece's Avatar
^^That's awesome . Was yours done by the factory?
post #10 of 203 (permalink) Old 05-17-2015, 04:48 PM
hpfontenot's Avatar
No, mine is a Line X thrown in by the dealer. They sprayed over the Gear-on plugs, but not the stake pocket plugs or the tailgate service hatch.
post #11 of 203 (permalink) Old 05-17-2015, 06:22 PM
i think there should be a grommet for the through hole in the sheet metal.
DHMag is offline
post #12 of 203 (permalink) Old 05-17-2015, 09:57 PM
hpfontenot's Avatar
The drilled hole is through a plastic plug, not sheet metal. I used silicone around the wire on mine, but from the pictures I can't imagine very much water getting through (very tight to the wire).
post #13 of 203 (permalink) Old 05-17-2015, 10:00 PM
My fault. i didnt read the write up, just looked at the pictures.
DHMag is offline
post #14 of 203 (permalink) Old 05-18-2015, 12:34 AM
TexazReece's Avatar
Just looked at some with the factory spray in bed liner and I see they left access to remove the panel.
Don Breda likes this.
post #15 of 203 (permalink) Old 05-18-2015, 06:06 PM
col_ed's Avatar
I hope that's the case. I'm not home so I can't confirm. Once I get back, I'll be checking and if it's open I'll be ordering this in a heartbeat.
2015 Canyon - All Terrain 4x4 CC LB QuickSilver
3" offroad steps, mud flaps, spray-in bed liner, Bose
HID headlight conv, led fogs, bakflip vp, weathertech mats
Blacked out front end, Colorado taillights
col_ed is offline
post #16 of 203 (permalink) Old 05-21-2015, 07:59 PM
Very cool. Definitely going to order one. Do you have a photo of where you tapped the wires?
Thanks for a great install guide!
Ernest t is offline
post #17 of 203 (permalink) Old 05-21-2015, 11:46 PM
I have owned my truck since Feb but I've never locked the tailgate. This thread got me thinking about it and so I just went out to lock it and found out that when I had the bed Linex'ed that they removed the tailgate access cover but ended up spraying the entire lock assembly covering to the point the key will barely turn the lock and it will not turn enough to lock the tailgate. So I guess I'll be stopping by the Linex shop so they can order me another lock assembly. Then the Pop & Lock I just ordered will work. Darn!
Warpster is offline
post #18 of 203 (permalink) Old 05-22-2015, 09:17 AM
Just ordered. Thanks for the write up!
EdSEL is offline
post #19 of 203 (permalink) Old 05-23-2015, 03:57 PM
CrashFix's Avatar
hpfontenot, how does the panel fit with the additional thickness of the spray liner, any issues there? Photo maybe?
Thanks
Canadian Colorado & Canyon Facebook Group by ColoradoFans.com
2015 Canyon SLT | 4WD | CC | SB | V6 | Summit White | Blk Leather | Nav | Bose | 5" Blk Steps | OBDLink MX Bluetooth Adapter & Torque Pro | Bull Ring Tie Downs | X-Pel Clear Film (Door Sill & Rear Lower Box) | Husky X-Act Contour Mats | Z71/All-Terrain Transfer Case Skid Plate | SuperSkidz #1Front & ZR2 #2 Skid plates | Rocker Pinch Welds Blacked Out | Debadged | Blizzacks (For Winter)
How to Search vBulletin.org effectively
CrashFix is offline
post #20 of 203 (permalink) Old 05-23-2015, 05:41 PM
hpfontenot's Avatar
Thanks
No issues. Even with the extra thickness the screws are long enough to thread properly.
Raining pretty hard right now, so no pictures yet.
CrashFix likes this.
