Made My Own Diff Drop Spacers Have Questions - Chevy Colorado & GMC Canyon
post #1 of 13 (permalink) Old 05-23-2019, 08:43 PM Thread Starter
Made some diff drop spacers (35mm OD, 15 ID, 10mm thick) although I'm not sure it's required for a 2" level? Also why do the kits only have 2 spacers when there are 3 attachment points ? Anyone know the length of the stock fasteners?
Rob_Angry is offline
post #2 of 13 (permalink) Old 05-23-2019, 09:06 PM
I made my own as quite a few have, Do a search, there are several threads that will tell you the length of bolt you will need. I bought mine at the hardware store.
You keep the back bolt in-no spacer, which will give the drive shaft the correct angle, you do need to LOOSEN that bolt a few turns to be ble to manuaver the diff around
I would have to figure out in US measurement what 10mm is to determine how long of a bolt you will need. If 3/8's then you can use the stock bolts with no problems.
2017 Deep Woods Green ZR2 CC
Truxedo Titanium cover
Go Rhino RB20 running boards
RC level
Hunter62 is offline
post #3 of 13 (permalink) Old 05-23-2019, 09:09 PM
16WhiteColly's Avatar
10 mm real close to 3/8.
2002 Pontiac Trans Am 5.7L V8 6 Spd. Manual, tuned, all bolt-ons, LT headers
See my album for pics
16WhiteColly is offline
post #4 of 13 (permalink) Old 05-23-2019, 09:51 PM Thread Starter
Yes 10 mm real close to 3/8" So there's enough thread on the stock bolts to use them?
post #5 of 13 (permalink) Old 05-24-2019, 07:44 AM
FAL guy's Avatar
10mm/25.4mm = .3937"
2018 GMC Canyon Crew SLT, 4x4, Cocoa/Dune, Ruby Quartz Tintcoat
BAK Fibermax Tonneau cover,Bedrug Bedliner
AMP PowerSteps, Morimoto HIDs, PopnLok
Thinkware F770 Front/Rear dashcam
FAL guy is offline
post #6 of 13 (permalink) Old 05-25-2019, 12:54 AM Thread Starter
#crickets ???
post #7 of 13 (permalink) Old 05-25-2019, 07:27 AM
Iceman62's Avatar
IMO...you're adding 10mm gap so get a 10mm longer bolt. There's a certain # of threads for a reason. It's not like you're buying a $pendy part & you already saved $$$ by making your own spacers.
The "Iceman" Cometh
MSGT, USAF (Retired)
18 Colorado LT Redline 4X4 Crew (Silver/Ice-Ice Baby)
Born in the US of A!
Iceman62 is offline
post #8 of 13 (permalink) Old 05-25-2019, 08:56 AM
FAL guy's Avatar
You probably wont find a bolt that is 10mm longer. Just get a bolt 1/2" longer and call it good, or for exactness, grind .1063" off.
FAL guy is offline
post #9 of 13 (permalink) Old 05-25-2019, 10:24 AM Thread Starter
My comment mainly in regard to the attachment points. There's 3 but we only use 2 of those. Seems kind of strange to me. It's lower but rotated back in regard to the C/L of the output shafts in my mind. From searches I've never seen this question answered.
post #10 of 13 (permalink) Old 05-25-2019, 10:25 AM Thread Starter
Usually metric fasteners are in mm length increments. At least where I work
post #11 of 13 (permalink) Old 05-25-2019, 10:27 AM Thread Starter
I didn't ask this....I asked if anyone knew the length of the stock fasteners. You know so I can have them "in hand" before starting the work. But hey thanks for your comment
post #12 of 13 (permalink) Old 05-25-2019, 10:33 AM
Rob_Angry, Rob-Smash.
soco_canyon is offline
post #13 of 13 (permalink) Old 05-26-2019, 02:33 PM
Banned
Your only lowering the front portion of the dif. So there are only 2 front mounting points. I installed the 1 inch dif drop and didnt like the angle it put on the mounting bushings because your angling it down in the front. It looked like over time that bushing would give out. I thought of doing only a 1/2 in drop would be better.
Sent from my SM-G965U using Tapatalk
FaustZR2 is offline
Similar Threads
AutoSpring 2.5, AAL, Diff Drop, 255/75/17 installed Crawler 2nd Gen Tires, Wheels, and Suspension 19 05-02-2019 10:24 PM
Front diff drop kit s_desmet 2nd Gen Chevrolet Colorado Forum / 2015 GMC Canyon Forum 0 06-02-2018 05:34 PM
Z71 4x4 drop questions... JoeyRock 1st Gen Modifications - Suspension 7 12-12-2006 09:11 PM
Creationism or Evolution? CanyonZ714x4 General Off Topic 1 426 10-15-2005 12:43 PM
Drop questions, HEY TONY (NORCALSTI)!!!!! Futuresweets-10 1st Gen Modifications - Styling 7 04-08-2005 08:44 AM
