Much visible difference between P265/65 and P265/70 tires? - Chevy Colorado & GMC Canyon
 7Likes
  • 2 Post By asesino
  • 4 Post By DenCoColorado
  • 1 Post By F8LZ71
post #1 of 6 (permalink) Old 05-15-2019, 02:14 PM Thread Starter
I have the stock P265/65/R17 Duratracs and a buddy wants my tires for his '16 'Rado.
I'm getting a 1.25 zone level kit installed this weekend so I think that should allow me to go with the slightly bigger P265/70/r17 tires (I might get the Falken Wildpeaks).
Not sure how big of a visible difference the truck gets with the slightly bigger tires, if any. Eventually, I might get a 1.5" zone lift kit and then upgrade the tires anyway (more $$$$) so I was thinking if the slightly bigger tires will still give me a somewhat 'lifted' look, I may go that route and just hold off the lift for couple of years.
Cheers!
[[ '19 GMC Canyon All-Terrain X :: DD SL1 lows, Bed Cover, BullBar, Wrangler AT Duratec 265/65/17, Door Visors, Gibson SFT Muffler, 1.25" Zone Level ]]
SSingh1975 is offline
post #2 of 6 (permalink) Old 05-15-2019, 02:31 PM
The 70s are an inch taller than the 65s. Combined with a potentially more aggressive sidewall (the Falkens look fairly aggressive), I think you would get a slightly lifted look. If you can offset the cost of the new tires by selling the old set, that's a good bonus.
Sent from my SM-G960U using Tapatalk
2017 Canyon CCSB V6, SLE All Terrain, Black
- Eibach Pro Truck Kit @ 2.7" - Zone 1.5" Body Lift - XD135 Grenade 17x8.5 +0 Offset - BFG All-Terrain KO2 285/70r17 - Trifecta Advantage+ Tune
- Air Dam Delete - 30" RC Curved Light Bar - LED Bed Lighting - Access Vanish Tonneau - Magnum RT Steps
- Planned: bed rack, full spare mount
asesino is offline
post #3 of 6 (permalink) Old 05-15-2019, 03:58 PM
Here's 265/65 vs 265/70 from relative same angles (265/70 is post level and more aggressive offset):
2019 ZR2 | 1" 589 Level | Method MR701 17x8.5" | Falken Wildpeak AT3W 265/70/17 | BD Squadron Sport Ditch Lights | CBI Light Brackets | Dantin Shock Skids | BAK Revolver X2 Tonneau | Swing Case
DenCoColorado is offline
post #4 of 6 (permalink) Old 05-16-2019, 06:13 AM
It appears by the photo that you removed the from mud flaps, if you did, was it due to rubbing?
XFordFanboy is offline
post #5 of 6 (permalink) Old 05-16-2019, 12:46 PM
You're exactly right....removed due to rubbing. However, as you can see from the first pic the flaps didn't do a whole lot when driving down a slightly wet dirt road. I did keep the rears on.
post #6 of 6 (permalink) Old 05-16-2019, 03:59 PM
F8LZ71's Avatar
Personally I don't think there is a huge difference in appearance when you step up between those 2 sizes assuming both tires are equal in terms of aggressiveness. A 265/65/17 Duratrac looks a little bigger than a 265/70/17 Michelin Defender IMO. While a 265/70/17 Duratrac looks massively larger than a 265/65/17 Defender. I have a hard time seeing the difference between a 275/70/17 and a 285/70/17 sometimes. A lot depends on the tread depth and sidewall characteristics. That being said, if you're lifting the truck definitely go bigger. :)
asesino likes this.
2018 Canyon SLE CCSB 3.6L - Eibach 2.7" Front Lift | Icon 2.0 rear shocks | 1.5" AutoSprings add-a-leaf + 1" rear lift blocks | DV8 887 179 wheels | Falken Wildpeak A/T3W LT285/70/17 | Custom bed rack |Tepui Baja Kukenam RTT | Morimoto HID | Tyger step bars | LED bed lighting | Midland MXT115 GMRS | Nilight 60w LED 4" pods | RotopaX, Maxsa traction mats and Recovery Gear | ZR2 skids |
Build Thread
Instagram
F8LZ71 is offline
