Who designed this effing thing - Page 2 - Chevy Colorado & GMC Canyon
 26Likes
post #21 of 30 (permalink) Old 03-28-2019, 05:56 PM
Just thinking ahead here, before I would do anything like cutting the bolt, I would have the new one in my hand first (it may be a specialty bolt & not just an ordinary one), because you don't want it to be on "National Back order" & find out after you cut it off !
Had a friend that did that about 15 yrs ago. He waited 5 months for the part & had to bum rides to work.
16WhiteColly and MV10 like this.
2019RedZR2 is offline
post #22 of 30 (permalink) Old 03-28-2019, 06:09 PM
16WhiteColly's Avatar
I would say that they probably put the bolt in from the back, because the head end of the bolt is lower and gives more clearance than the screw end, and less likely to rub a hole in the fuel tank. If you go back with the stock bolt, I could see having to cut the screw end of just past the Nut for clearance.
See my album for pics
16WhiteColly is offline
post #23 of 30 (permalink) Old 03-28-2019, 08:05 PM
MV10's Avatar
Ha! I had that happen on a 73 Benz 280SE I was slowly restoring. Front brake hardware was metric, rear was SAE.
In about 2002, a single front caliper bolt cost $35 plus airfreignt and took eight weeks to deliver from Germany.
2017 Colorado LT V6 CCSB 2WD • mfg date 11-16 • Belltech 999SP 3/4 drop • Raceline 927M Mamba HD 20x9 wheels • all LED lighting inside and out • DRL relocation harness • LineX • Lomax Tri-Fold aluminum tonneau • de-badged • bowtie blackout • painted pinch-weld & window trim • power tailgate lock • Pedal Commander • Katzkin leather • tint • Kicker amp/sub
MV10 is offline
post #24 of 30 (permalink) Old 03-28-2019, 08:15 PM
Originally Posted by Jacqson View Post
If you own a diesel and you want to replace the left side rear shock you have to remove and lower the def tank to get access to the upper bolt..Ask me how I know......
Originally Posted by Daveski65 View Post
yea not looking forward to this as i will be installing my fox 2.5 shocks in the next couple weeks
I did it by loosening the def tank but not removing it. It drops onto the spare. Do that and you can get the top left bolt out with some wiggling. There's a little indent at the top of the tank that seems to be there for that reason.
soco_canyon is offline
post #25 of 30 (permalink) Old 03-29-2019, 01:35 AM
Jacqson's Avatar
I'm aware of that. I should have used the word unfasten and not the word remove.....My bad..
lqdchkn likes this.
2018 Chevy Colorado, Z71, CCSB, Duramax, Kinetic Blue Metallic....
Jacqson is offline
post #26 of 30 (permalink) Old 03-29-2019, 11:14 AM
Moderator
No you dont. I didnt.
yea not looking forward to this as i will be installing my fox 2.5 shocks in the next couple weeksyea not looking forward to this as i will be installing my fox 2.5 shocks in the next couple weeks
Think about it while youre under there and you might find another solution.
You will need to loosen it but it definitely doesnt need to come out.
lqdchkn is offline
post #27 of 30 (permalink) Old 03-29-2019, 01:37 PM
Jacqson's Avatar
I did clarify my statement in the post above and if you managed to get the upper left shock bolt out without having to move the def tank a bit, then I sure would like to know how you did it.
Jacqson is offline
post #28 of 30 (permalink) Old 03-29-2019, 06:02 PM
Moderator
I think I hit the reply before I got to page 2. But yes you are correct, movement is required removal is not
lqdchkn is offline
post #29 of 30 (permalink) Old 03-30-2019, 08:44 AM
like they say always more then one way to skin a cat.
i think its easy,,i looked under there..will just loosen and move enough to get out enough to pull out old shock and install new one
lqdchkn likes this.
2016 Gmc Canyon CCLB 2.8 Duramax quicksilver
Daveski65 is online now
post #30 of 30 (permalink) Old 04-01-2019, 02:46 AM
Originally Posted by shibbs View Post
You think that's bad, try doing spark plugs on a Subaru.
Doing spark plugs on a subaru is not bad at all, whether EA, EJ, EZ, FA, or FB.
2016 Colo Z71 4X4, CCLB Duramax Cyber Grey
2017 All Terrain Bobcat camper.
Air dam delete, Bilstien 5100's w/ 2" Front setting. Firestone Ride Rites.
Nokian Rotiiva AT Plus LT265 70 17. Hypertech Speedo Calibrator.
Stubby Jr 2" antenna. Weathertech floor liners, mudflaps, seat covers, and window deflectors. Camerasource back up camera for camper.
Lots of maps and dreams and climbing gear.
Orca 26L, Coleman Steel Belted 54L.
hand foot maneuver is offline
Similar Threads
some thing other then scangauge 2 olds88 General Truck Chat 5 10-22-2009 02:50 AM
new to this whole thing FoX MaN 835 1st Gen Modifications - Suspension 1 04-12-2009 11:52 PM
biggest most heavy thing towed with I4 ko66 General Truck Chat 23 11-02-2007 03:44 AM
Whats the biggest thing youve towed? Playyer General Truck Chat 8 06-16-2004 09:42 PM
What is the first thing you would get? coloradogrl General Truck Chat 14 04-08-2004 02:55 PM
