Rear suspension, blocks, Add-a-Leaf - Chevy Colorado & GMC Canyon
 10Likes
post #1 of 23 (permalink) Old 02-10-2019, 09:26 PM Thread Starter
Question Rear suspension, blocks, Add-a-Leaf
I am looking for clarification on adding rear blocks and/or a leaf spring. Rear shocks designed to work with a lift do not provide the lift on their own. They require a block or added leaf spring. So can you add a block or leaf with the stock shocks?
Does anyone have any recommendation on Eibach Pro-Truck rear shocks? I'm looking at putting the RHA Eibach in the front and trying to decide on the rear. I'm also looking at adding the Auto Springs Add a Leaf to the rear. These say 1"-1.5". Is that an option (to do 1 or 1.5) or just variability. The Eibach rear shocks say up to 1". Are they compatible with the add a leaf? Thanks.
Greg.allou is offline
post #2 of 23 (permalink) Old 02-10-2019, 10:50 PM
I ran a 1" rear block on stock shocks for a long time. It was quite bumpy back there. Railroad tracks sucked as the rear would bounce around and kick out quite often. Switched to the eibach shock and it helped with control quite a bit, and then eventually switched to a add a leaf and help a bit more. In all the combinations I've done so far on mine, the eibach setup up front with their strut and spring on second notch goes well with a 1" rear block to be pretty level. If you go to the third, go with an add a leaf out back.
Sent from my LM-G710 using Tapatalk
F8LZ71 and 16WhiteColly like this.
Savingpvtpyle is offline
post #3 of 23 (permalink) Old 02-11-2019, 12:27 PM
as per eibach....they dont formally say it, but email them and they will say their shocks have been used successfully with 2 inch blocks.
awesomeman is online now
post #4 of 23 (permalink) Old 02-11-2019, 01:02 PM Thread Starter
Thanks. That’s all helpful. Does anyone know if there’d be a noticeable difference going with the Fox 2.0 Performance Shock over the Eibachs? They’re a little more expensive so trying to decide if they are worth it.
post #5 of 23 (permalink) Old 02-11-2019, 01:17 PM
Crawler's Avatar
Check with @F8LZ71. I believe he has the ICON rears for 0-2” mixed with an eibach front setup.
He could probably give some good information on what you’re looking for.
He’s really good about researching his purchases and could probably shed some light on his choice.
2018 CCSB Z71 4wd-AutoSprings 2.5,AAL,DifDrop,Links,255/75/17BFG Mud
2015 CCSB 2500 Duramax Z71 4wd
95 1500 Dodge Cummins conversion-Back halved,4Link,Caged-Build by EIKON Diesel
Crawler is online now
post #6 of 23 (permalink) Old 02-11-2019, 10:52 PM
F8LZ71's Avatar
I wasn't sure if the Eibachs could handle a 2"+ rear lift so I went with Icons because they are rated for 0-2". The Fox are listed as 0-1" unless you get the Silverado shocks which are longer.
The Fox 2.0s measure 15.05" X 23.15"
If you can find the compressed and extended lengths for Icon and Eibach you can make an informed decision. :)
I do know the Icons easily handle a 1" block and Autospring AAL.
Here are the oem shocks compared to Icons at full extension.
2018 Canyon SLE CCSB 3.6L - Eibach 2.7" Front Lift | Icon 2.0 rear shocks | 1" AutoSprings add-a-leaf + 1" rear lift blocks | RC 1.25" body lift | DV8 887 17×9 wheels | Falken Wildpeak A/T3W LT285/70/17 | Custom bed rack |Tepui Baja Kukenam RTT | DV8 rear bumper | DV8 front bumper | DV8 12k winch | Morimoto HID | Tyger step bars | LED bed lighting | Midland MXT115 GMRS | Nilight 60w LED 4" pods | RotopaX, Maxsa traction mats and Recovery Gear | DV8 + ZR2 skids |
Build Thread
Instagram
F8LZ71 is offline
post #7 of 23 (permalink) Old 02-20-2019, 07:16 AM Thread Starter
I found these part numbers for the GM rear lift blocks in another thread, but now I can't find that thread. Can anyone confirm that these are the correct parts for a 1" block?
Spacer-15885530
Bolt-11569811
I think these are the parts they listed for 1", but the GM parts doesn't list the height since it not really made for the Colorado/Canyon. Can the stock nuts be reused with this setup?
Thanks
post #8 of 23 (permalink) Old 02-20-2019, 09:32 AM
I installed the AALs and Icon shocks. I installed the shocks a few weeks before I installed the AAL. I experienced an interesting phenomenon I think I am able to explain. AALs alone should stiffen the ride a bit over stock, vs using blocks. You are increasing the spring rate to achieve the lift, which is also why they claim increased payload(can't confirm this because other factors may be the limiting piece, axles, tires,etc).
I installed the SHOCKS and experienced a much stiffer ride. I was pretty unhappy. I then added the AALs and the ride softened a bit. I think the Icon shocks are overdamped for the stock spring rate, so they were dominating the system. Shocks are designed to bring the system back to equilibrium, springs are designed to absorb impacts. The springs were dominated by the shocks and unable to absorb much impact. After I added the AALs the ride softened up a bit (still presumably stiffer than stock), because by increasing the spring rate, the springs became the dominant in the system, and damping was slightly underdamped(ideal).
TLDR: AALs will ride slightly stiffer than stock, but Theoretically increase payload. Icon shocks are overdamped with stock leaf springs, Add a leafs help bring the system back into equilibrium. I probably would avoid Icons with just blocks.
btsbarton is offline
post #9 of 23 (permalink) Old 02-20-2019, 10:34 AM
I have installed the Eibach stage one kit and the AAL. The front are at the 2.7 inch to level the truck with the springs to add the additional 1 inch and the AAL added the 1 inch in the rear. The ride is great. The truck does not bounce around at all.
One thing to be aware of on the AAL, I unintentionally installed one backwards which caused it to ride on the band clamp of the spring pack and cause a noise every time I hit a bump or even got in and out of the truck. Rookie mistake that I should not have made, but it was the last thing going in and I was too excited and wanted to take it for a ride.
jjs34748 is offline
post #10 of 23 (permalink) Old 02-23-2019, 01:17 PM
I have a quick question. How do you like the shocks that came with that kit?
Johnny Kayak is offline
post #11 of 23 (permalink) Old 02-23-2019, 01:47 PM
White016's Avatar
Do you know if I can use stock Silverado shocks on the rear with a 1" block? What year Silverado?
THANKS!
2016 Colorado 4x4 CC SB V6 LT
White016 is offline
post #12 of 23 (permalink) Old 02-23-2019, 02:11 PM
White016's Avatar
@F8LZ71
THANKS!
Never mind, answered my own question. Rock auto has OEM specs listed on their shocks.
2016 Silverado is 1.51" longer compressed, 2.26" longer open.
Should be a good choice, just a little worried about the extra extension from now with the block but should be ok.
White016 is offline
post #13 of 23 (permalink) Old 02-24-2019, 07:37 AM
F8LZ71's Avatar
@F8LZ71
Keep in mind the Silverado shocks are likely valved for a higher weight which could make them ride stiffer on our trucks if our rear ends and wheel/tires are significantly lighter.
White016 and 16WhiteColly like this.
Build Thread
Instagram
F8LZ71 is offline
post #14 of 23 (permalink) Old 02-24-2019, 10:53 AM
1.5” longer compressed sounds like the shock will bottom out before the rear hits the bump. Is that right?
16WhiteColly likes this.
nicul15 is offline
post #15 of 23 (permalink) Old 02-24-2019, 12:19 PM
White016's Avatar
maybe, but I have a 1" block so that makes it only .5" longer in a sense.
White016 is offline
post #16 of 23 (permalink) Old 02-25-2019, 09:02 PM
Yeah it might be worth looking into. If the bump isn’t contacting it doesn’t matter if it’s 0.5” or 2”. You’re gonna break something. And I will say with only 150lbs in the bed it uses the bumps often!
nicul15 is offline
post #17 of 23 (permalink) Old 06-11-2019, 05:15 PM
Sorry to bring up the old thread but has anyone added aal and rear block in the back? Looking for 2-3 inch rear lift to closer match the 3.5 SST front lift.
Riley Kotylak is offline
post #18 of 23 (permalink) Old 06-11-2019, 06:25 PM
F8LZ71's Avatar
Yeah but AAL tend to settle so you're not likely to get more than 1" out of one for long. You'll also need longer shocks with 2"+ inches of rear lift. At 3" you'll likely need a custom shock or maybe one for a Silverado. The stock shocks just aren't long enough to handle that kind of lift.
Build Thread
Instagram
F8LZ71 is offline
post #19 of 23 (permalink) Old 06-11-2019, 07:37 PM
I would call Rough Country and see if they would sell you the block/U-bolts/rear shocks from their 4 inch lift.
https://www.roughcountry.com/gm-susp...-kit-221c.html
actually I would call Ready Lift and see what they may have
If not and you have a good 4wd shop near you they can source a good shock that will work, like a Rancho 5600 series, you can make a block and figure out what u-bolts you will need, you will also need longer brake lines for the rear
F8LZ71 likes this.
2017 Deep Woods Green ZR2 CC
Truxedo Titanium cover
Go Rhino RB20 running boards
RC level
Hunter62 is offline
post #20 of 23 (permalink) Old 06-12-2019, 12:22 PM
I'm going to call around and see. Someone has to have put 2-3 inches of rear lift on these trucks. Just held up on what I'd need for blocks and brake lines, it looks like the drivers side would accommodate 2-3 inches but the passenger side brake line looks maybe short.
Edit passenger side is a wire, looks like some length could be freed up if necessary
Similar Threads
Chevrolet : Colorado Crew Cab 126.0" WB 1SE LS Z71 Crew Cab 126.0" WB 1SE LS Z71 4 dr Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 07-21-2015 03:10 PM
Chevrolet : Colorado 2WD 126.0" LT w/3LT 2 wd 126.0 lt w 3 lt low miles 4 dr crew cab Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 09-17-2014 10:10 AM
Chevrolet : Colorado 2WD Ext Cab 125.9" LS CLEAN CARFAX FROM GA RUST FREE 2.9L 4 CYL Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 09-03-2014 04:30 PM
Chevrolet : Colorado 126.0" WB 4WD LT w/2LT 126.0 Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 08-13-2014 11:00 AM
