How to lift your Colorado or Canyon and what tires fit - Page 6 - Chevy Colorado & GMC Canyon
 87Likes
post #101 of 128 (permalink) Old 03-01-2019, 11:59 AM Thread Starter
F8LZ71's Avatar
Originally Posted by Tsmith239 View Post
I just installed the RC 3.25 kit with 1.5 blocks in the rear. Fuel vector 20x9 with 275/60/20 falken atw3 do not fit without major cutting. Had to trim up the body mounts and liners on both sides. Looks awesome though 👍🏼 I will post more pictures soon. Currently getting an alignment and trimming done
Can you please list the offset for those wheels in your original post? :)
2018 Canyon SLE CCSB 3.6L - Eibach 2.7" Front Lift | Icon 2.0 rear shocks | 1.5" AutoSprings add-a-leaf + 1" rear lift blocks | DV8 887 17×9 wheels | Falken Wildpeak A/T3W LT285/70/17 | Custom bed rack |Tepui Baja Kukenam RTT | Morimoto HID | Tyger step bars | LED bed lighting | Midland MXT115 GMRS | Nilight 60w LED 4" pods | RotopaX, Maxsa traction mats and Recovery Gear | ZR2 skids |
Build Thread
Instagram
F8LZ71 is offline
post #102 of 128 (permalink) Old 03-08-2019, 01:47 PM
Trundle's Avatar
Originally Posted by F8LZ71 View Post
Well, here I go. 2016 Z71 Diesel with stock wheels. I have the Eibach shocks at the stock height, Eibach springs for 2" of lift, and 1" blocks in the back. I just ordered 265/70/17 Continental A/T. I really hope they fit...fingers crossed. Should get installed today.
This thread was very helpful, thanks!
F8LZ71 likes this.
2016 CCSB Z71 Duramax / Eibach Pro Truck Kit on Stock Setting, Springs give 2" in the front, Icon 1" blocks in the back, Continental Contact Terrain A/T 265/70/17
Trundle is offline
post #103 of 128 (permalink) Old 03-08-2019, 08:48 PM
Based on all the input here, I'm going to be very surprised if that does not work just fine! Same size I am moving to as well, so I'll be looking for your feedback.
Trundle and F8LZ71 like this.
http://badges.fuelly.com/images/sig-us/545200.png
Planned Mods:
Homelink
RandyNC is offline
post #104 of 128 (permalink) Old 03-08-2019, 08:52 PM Thread Starter
F8LZ71's Avatar
Right on! They should fit fine and probably won't rub the frame except in extreme circumstances. Keep us posted and don't forget photos.
Trundle likes this.
Build Thread
Instagram
F8LZ71 is offline
post #105 of 128 (permalink) Old 03-08-2019, 09:19 PM
chevy_dude29's Avatar
I have the V6 with Fox 2.0 coliovers in the front which lift it 2 inches and no lift in the rear and im running 265/70/17 falken tires and I only have rubbing when wheels are at full lock. Not supper bad but definitely noticeable.
Instagram: Chevy_Cumrado
chevy_dude29 is offline
post #106 of 128 (permalink) Old 03-08-2019, 10:18 PM Thread Starter
F8LZ71's Avatar
I would have predicted that with the Falkens. The TerrainContacts are a bit tamer ( a tiny bit smaller too) so should have more clearance. The Duratracs tend to cause rub as well. :)
Build Thread
Instagram
F8LZ71 is offline
post #107 of 128 (permalink) Old 03-08-2019, 10:42 PM
Sorry I know this was mentioned but cant find it. What’s the largest tire I can use as a spare
Thanks
F8LZ71 likes this.
awesomeman is offline
post #108 of 128 (permalink) Old 03-08-2019, 11:04 PM Thread Starter
F8LZ71's Avatar
Thanks
I believe a 255/75/17 (32.1") fits and @Thunderbear is running a 265/70/17 (31.7") under his truck. I think he didn't have to modify anything to make it fit but maybe he can elaborate. I think I've seen where someone fit an even larger tire but I'd have to do some searching. I'll update the 1st post when we come to a consensus.
Build Thread
Instagram
F8LZ71 is offline
post #109 of 128 (permalink) Old 03-08-2019, 11:54 PM
Trundle's Avatar
Install done, fits without touching anything, at least when not moving. I think these are going to work! :) I post some pictures when I can take some good ones.
F8LZ71 and RandyNC like this.
Trundle is offline
post #110 of 128 (permalink) Old 03-09-2019, 08:20 AM
SO @F8LZ71 - I never really thought much about the same size (265/70 17) being different with different brands. Is that mainly due to the design of the side of the tire? To that end, based on the post above, what about BFG KO2's? More likely to rub or about the same as others?
Planned Mods:
Homelink
RandyNC is offline
post #111 of 128 (permalink) Old 03-09-2019, 09:47 AM Thread Starter
F8LZ71's Avatar
Yeah you would think that every tire within a listed size would be the same dimensions but they are not. Some tires run larger than others. If you add sidewall armor and larger shoulder lugs for off-road protection and traction the tires may be even larger. For example, the Wildpeak AT3W P285/70/17 is listed as 32.8" in diameter and 11.3" section width. The LT285/70/17 is 33" in diameter and 11.6" section width. The difference isn't huge but could be just enough where the LT would rub and the P-metric wouldn't.
Now compare the LT285/70/17 Wildpeak AT3W at 33" x 11.6" to the LT285/70/17 BFG KO2 at 32.7" x 11.5" with 9.2 tread width. Both are the same listed size but the Wildpeak is actually larger and could cause rubbing on some vehicles where the KO2 might not.
Now in the case of the Duratrac which is sort of a hybrid all-terrain/mud tire the section width (widest part from sidewall to sidewall) is smaller than the highway oriented Defender BUT the Duratrac is both taller AND wider at the tread width which makes it much more likely to rub on our trucks because the tight spots in our wheel wells are where the tread would touch, not the sidewall.
Duractrac LT285 is 33" x 11.2" with 9.1" tread width
Michelin Defender LTX LT285 is 32.7" x 11.5" with 8.8" tread width
So if you're tight on room and worried about rubbing you should be looking at actual tire diameter, section width and tread width if they list it. Unfortunately Falken doesn't list their tread width.
RandyNC likes this.
Build Thread
Instagram
F8LZ71 is offline
post #112 of 128 (permalink) Old 03-09-2019, 10:03 AM
I just installed a 6in lift and put on 286/65R18 KO2 on my rig(just shy of 33in). There is some slight rubbing so going to have to look at cutting and trimming. I was hoping that with the lift everything would fit just right, but I was wrong.
Muspelheim1 is offline
post #113 of 128 (permalink) Old 03-09-2019, 10:05 AM
monteholic's Avatar
also consider rim width can alter tire dimensions
2019 ZR2 Dusk Edition
2003 LS1 Corvette
1971 Monte Carlo SS454
monteholic is offline
post #114 of 128 (permalink) Old 03-09-2019, 10:52 AM
Waiting on my Fox 2.5 setup,,Accutuneoffroad building and tuneing shocks,all with res and DCS adjusters, Icon UCAs with Delta joints, Went with 265/70/17 Falken Wildpeaks AT3, going to get prothane sway kit.Hopefully will look good,,Probably should have gone with 275/70/17..?
Not lifting back till all done and then maybe a block or add a leaf. I do tow with it.
2016 GMC Canyon All terrain CCLB 2.8 Duramax
2016 Gmc Canyon CCLB 2.8 Duramax quicksilver
Daveski65 is offline
post #115 of 128 (permalink) Old 03-09-2019, 12:13 PM
monteholic's Avatar
255/75R17 is another option (32.1")
2003 LS1 Corvette
post #116 of 128 (permalink) Old 03-09-2019, 12:29 PM
yea i looked at that size too,,too much like a pizza cutter,,want the wider tire for stability and will most likely change out rims with a 0mm backspace for that peaking out look and wider stance.
post #117 of 128 (permalink) Old 03-09-2019, 01:07 PM
Trundle's Avatar
Install done, fits without touching anything, at least when not moving. I think these are going to work! 🙂 I post some pictures when I can take some good ones.
Here's a picture. Really happy with it.
Trundle is offline
post #118 of 128 (permalink) Old 03-09-2019, 03:08 PM
Good read - thanks for posting.
F8LZ71 likes this.
WillB is offline
post #119 of 128 (permalink) Old 03-09-2019, 03:13 PM Thread Starter
F8LZ71's Avatar
It looks good! Still no rubbing?
Build Thread
Instagram
F8LZ71 is offline
post #120 of 128 (permalink) Old 03-09-2019, 04:02 PM
Jusbecuz's Avatar
RC 2" front, 1.25" block in the rear. Cooper AT3 4S 265 70 17. They fit great, but I removed the front WeatherTech mudflaps as they were really close.
F8LZ71, maxbee25 and AJ88 like this.
2017 Colorado LT 4x4 CCSB
Jusbecuz is offline
