Largest on stock rim and or 20s - Chevy Colorado & GMC Canyon
post #1 of 17 (permalink) Old 06-19-2017, 08:46 PM Thread Starter
What's the largest tire the stock rim can safely fit and will fit the truck with no level/lift?
Also I may be going with 20s. What's the largest tire and best rim width/offset combo that'll fit on a stock suspension
While I'm sure the answer is in the posts I've bounced around for like 30 mins and didn't find anything.
Thanks
awesomeman is offline
post #2 of 17 (permalink) Old 06-19-2017, 10:02 PM Thread Starter
I'm thinking 275 55 20s on the fuel d546. But not sure if it may fit. What offset do you guys recommend
post #3 of 17 (permalink) Old 06-19-2017, 10:52 PM
275/55/20 w/o level or lift wont fit...265/50/20
Andrew Aubuchon is offline
post #4 of 17 (permalink) Old 06-20-2017, 02:01 AM
cire808's Avatar
You might want to check the Canyon Denali wheel and tire setup which comes 20's stock
2016 Chevy Colorado LT/Silver Ice Metallic/3.6L DOHC V6/LT Convenience Package/Black Bowtie Emblems/AMP Research PowerSteps/Access TonnoSport Cover/Access Bed Mat/Spray Bedliner/Carbon Fiber Wrap Interior Trims/Stubby Jr/Z71 Grille Swap/OEM Fender Flares/BajaKits UCA/Kings 2.5 Coilover Shocks/Maxtrac 4" Lift Spindles/Maxtrac 4" Rear Blocks/20x9 Fuel Off-Road Triton/275.55.20 Nitto Terra Grappler G2
cire808 is offline
post #5 of 17 (permalink) Old 06-20-2017, 09:52 AM Thread Starter
what offset do I need to run 265/50/20. the wheels i like come in 1 or 20 offset
post #6 of 17 (permalink) Old 06-20-2017, 11:40 AM
The stock Denali Canyon comes with 255-55-20 and there is not much more room with out mods.
They factory tire is 30.5 inches. I think the wheels are 20x8.
hyperv6 is offline
post #7 of 17 (permalink) Old 06-20-2017, 12:39 PM
factory 18" on canyon SLT is 265/60/18, offset is +33...I would make sure nothing less than a +12, but would talk to reputable tire and wheel shop
post #8 of 17 (permalink) Old 06-20-2017, 02:04 PM Thread Starter
damn there are very few choices in that size.
post #9 of 17 (permalink) Old 06-20-2017, 02:17 PM Thread Starter
whats the max safe size to put on the stock 17s?
post #10 of 17 (permalink) Old 06-20-2017, 03:16 PM
I expect that to change. When we bought the wife's Terrain there was few choices for 19" tires for it and now there are a good number. With the number of SUV and trucks going to 20" I expect more to be with us soon. It takes time for the market to react.
I am wondering how the Bridgestone will hold up. I have never has a set I was happy with OE yet from them or Firestone. They often do not offer their best to the OE market like many others.
In the dry they have been good but the Hankooks we had they were worthless in the snow and rain> I hope not to repeat that 4x4 or not.
I have family in the tire industry and can get some decent discounts on tires as long as they offer what I want.
The Denali is tuned more for the road and I have added a rear sway bar. I will keep with a good all season.
hyperv6 is offline
post #11 of 17 (permalink) Old 06-20-2017, 04:04 PM
265/65r17
265/70r17 can be done, but a rub can occur dependent on particular tire model designs.
post #12 of 17 (permalink) Old 06-23-2017, 09:36 AM Thread Starter
I guess I may wait a few more months and see if any options come out. I really want 20s and I really dont want to lift.
post #13 of 17 (permalink) Old 06-24-2017, 01:41 PM
The 255/55/20 is a 31.1 inch tire, not 30.5. I have a Denali diesel and they had some room left for sure. I put a set of 18s on with 265/65/18 ATs and I don't run anywhere without a lift or level.
Seansmp8 is offline
post #14 of 17 (permalink) Old 06-24-2017, 02:04 PM Thread Starter
What wheels did you go with
post #15 of 17 (permalink) Old 06-24-2017, 03:21 PM
I just picked up a set of 18" Canyon wheels. I kept my Denali wheels Bc I do like the look. I just didn't want to go with a 265/50/20 for two reasons. 1. The sidewall is smaller than my stock 255/55/20 and it looks very weak. I also did not want the odometer reading more miles than I'm actually traveling (255/55= 31.1" 265/50= 30.5").
Seansmp8 is offline
post #16 of 17 (permalink) Old 06-29-2017, 12:45 PM
I have been wondering about tires size as well. I have time before getting wheels and tires, so plenty of research to be done. I will not be lifting my truck since it will be mostly used for towing. I really like the look of thick tires though, so I am wondering about the thickest tires that can be put on these trucks. I am currently looking at the 18x9 Fuel Vectors. I have also toyed with the possibility of putting Bushwacker flares on, which would allow for another 1.5" of thickness.
Thoughts? Suggestions? TIA
2016 Chevy Colorado Z71 Duramax | Summit White | Duramaxtuner | More to follow... (MUCH MORE!!! )
ShirtsCO is offline
post #17 of 17 (permalink) Old 04-16-2019, 02:16 PM
I've been hopping between older threads here and haven't gotten a real concrete answer about max size tire on 20's. I'm looking at a helo he914 20x9 and was considering 275/50r20 considering it's very close to stock height. 275/55 will run higher and very close and rub the flaps. Will 285/50 work? This is a more popular size. Not really interested in a lift.
Was using this for reference.
https://tiresize.com/wheel-offset-calculator/
Derwynn is offline
