*** Wheel & Tire Gallery *** - Page 46 - Chevy Colorado & GMC Canyon
 1049Likes
post #901 of 988 (permalink) Old 03-05-2019, 12:00 PM
Originally Posted by 1STGMC View Post
@asesino
hey bro what's the specs on ur wheel setup? I'm looking to ditch the wheel spacers and go to a 20x10 fitting 33's from 275/55 to 275/60. We pretty much have the same suspension setup and I like how ur wheel setup fills in the wells.
Sent from my SM-G955U using Tapatalk
He has it in his signature
1STGMC likes this.
2016 Colo Z71 4X4, CCLB Duramax Cyber Grey
2017 All Terrain Bobcat camper.
Air dam delete, Bilstien 5100's w/ 2" Front setting. Firestone Ride Rites.
Nokian Rotiiva AT Plus LT265 70 17. Hypertech Speedo Calibrator.
Stubby Jr 2" antenna. Weathertech floor liners, mudflaps, seat covers, and window deflectors. Camerasource back up camera for camper.
Lots of maps and dreams and climbing gear.
Orca 26L, Coleman Steel Belted 54L.
hand foot maneuver is offline
post #902 of 988 (permalink) Old 03-05-2019, 12:07 PM
1STGMC's Avatar
thanks man, I'm using the Tapatalk app so it doesnt show anyone's sig.
Savingpvtpyle likes this.
2019 GMC Canyon Emerald Metallic Blue 2wd 4cyl - Eibach Pro-lift at 2.7" - 1.25" Silverado Block, 1.5" Wheel Spacers - Rough Country 1.25" Body Lift - 275/55/20 Toyo Open Country AT2 on Denali Rims - Trifecta Advantage+ - Lund Hood Deflector - Lo-Pro AVS Window Visors - Tonno Pro LoRoll Tonneau Cover - Pop & Lock - LED bulbs front to back - 5% Tint Ceramic Tint
1STGMC is offline
post #903 of 988 (permalink) Old 03-05-2019, 12:40 PM
Ahh, copy. Here:
2017 Canyon CCSB V6, SLE All Terrain, Black
- Eibach Pro Truck Kit @ 2.7" - Zone 1.5" Body Lift - XD135 Grenade 17x8.5 +0 Offset - BFG All-Terrain KO2 285/70r17 - Trifecta Advantage+ Tune
- Air Dam Delete - 30" RC Curved Light Bar - LED Bed Lighting - Access Vanish Tonneau - Magnum RT Steps
- Planned: bed rack, full spare mount
post #904 of 988 (permalink) Old 03-05-2019, 11:12 PM
@aesino
Our suspension setup is pretty similar, yeah. My details are:
Eibach pro kit @ 2.7"
1.5" Zone body lift
17x8.5 +0 offset XD135 Grenade Off-Road
285/70r17 BFG KO2
Your lift definitely looks good and beefing up the tires will look even better! I think you should be able to fit the 275/55r20 or 275/60r20. I'm guessing you'll need to do most/all of the following:
- Go to a wheel with less positive offset, but you probably already know that since you're running spacers already.
- The stocks are +33 offset. I think @F8LZ71 has zeroed in on +18 to push the wheel out enough to clear the frame at full lock but not so far as to cause significant trouble with fender rubbing.
- I love my 0 offset for the poke, but I had to do more significant trimming of the pinch weld and rear wheel well trim area to clear them. It was pretty easy, but not everyone is willing to make this mod. Details of what I did are in this post.
- Regardless of which offset you choose, you'll likely have to do *some* pinch weld trimming. My initial trim was to just to cut the corner off the front edge of the pinch weld. That got really close to fully clearing, so if you go with +18, that might be enough.
- Install sway bar relocation brackets. This moves the sway bar forward an inch or so (and drops it slightly - 0.25-0.5") to keep the wider tires from rubbing the sway bar.
- Install longer sway bar end links. After the lift and sway bar relo, the angles are off a fair amount. Longer end links will straighten them back up.
- the sway bar relo and end links are both relatively cheap and easy (compared to new wheels and tires), so I'd just do them both for good measure.
- Trim the front waffle plastic behind the fender liner in the front of the wheel well
- This is a super common mod for larger tires, and there are tons of threads and pics on doing this. Details of what I did are in this post.
Hope this helps!
F8LZ71 likes this.
asesino is online now
post #905 of 988 (permalink) Old 03-05-2019, 11:25 PM
1STGMC's Avatar
1.5" Zone body lift
285/70r17 BFG KO2
Hope this helps!
thanks bro. I actually got 275/55/20 now, cant believe a 275/60 is a inch taller which I'm think about doing along with probably 20x9 +0 offset. I pretty much did every mod u listed besides the longer endlink which I'll most likely do sometime soon. The wheel setup will probably be the last thing I do on this truck since I'm not too amazed on the styles available, I tend to get picky on what shoes I use on my toys. For example, I only owned this truck for about 6 months and these denali's is actually the 3rd wheel setup.
1STGMC is offline
post #906 of 988 (permalink) Old 03-08-2019, 01:32 AM
cire808's Avatar
Nice truck! You live in town? Would like to see your truck some day bro.
2016 Chevy Colorado LT/Silver Ice Metallic/3.6L DOHC V6/LT Convenience Package/Black Bowtie Emblems/AMP Research PowerSteps/Access TonnoSport Cover/Access Bed Mat/Spray Bedliner/Carbon Fiber Wrap Interior Trims/Stubby Jr/Z71 Grille Swap/OEM Fender Flares/BajaKits UCA/Kings 2.5 Coilover Shocks/Maxtrac 4" Lift Spindles/Maxtrac 4" Rear Blocks/20x9 Fuel Off-Road Triton/275.55.20 Nitto Terra Grappler G2
cire808 is offline
post #907 of 988 (permalink) Old 03-08-2019, 02:03 AM
1STGMC's Avatar
Thanks bro, yea I live in kalihi but mainly roam metro area the island if not the east side were I see a bunch of guys trailing at the beach. I think I seen ur truck a few times around the freeway heading from kapiolani.
1STGMC is offline
post #908 of 988 (permalink) Old 03-15-2019, 12:31 AM
F8LZ71's Avatar
Just a little update on the new DV8 887 wheels.
I'm still getting the occassional rub at something near full lock but I don't think it's hitting the frame. I'm going to paint the frame again and keep and eye on it but I think I'm rubbing the fender liner omewhere from the way it sounds. Everything was fine for a week or so with zero rub but I wonder if my alignment is tweaked with all the snow wheeling I've been doing. The steering feels twitchy at high speeds too.
Despite whatever is going on with my alignment I'm very happy with the wheels. I haven't noticed and feeling of power loss despite their weight and they ride smooth on and off-road. I drive pretty rough when trying to make it through large puddles or dips on the trail when there is a goid chance of getting stuck. The front end dives into the hole then springs back up pointing at the sky when exiting and there isn't a hint of rub or other weird noise. I'm pretty impressed with how the Eibach Pro Kit shocks/springs are handling the abuse too!
I think the magic offset number for a 285/70/17 is around +12 to +15 depending on your specific tire, wheel width, lift type/height and alignment specs. For narrower tires the +18 to +23 offset is good for reducing the chance of rub.
DV8 887 17x9 +20mm offset, 32lbs $139/ea
Filmed before I added the new wheels but this is the kind of fun we have when snow wheeling when someone got there first and made deep ruts. It's hard on your suspension and wheels changing direction so abruptly when you bang off the hard rut edges. :)
2018 Canyon SLE CCSB 3.6L - Eibach 2.7" Front Lift | Icon 2.0 rear shocks | 1.5" AutoSprings add-a-leaf + 1" rear lift blocks | DV8 887 179 wheels | Falken Wildpeak A/T3W LT285/70/17 | Custom bed rack |Tepui Baja Kukenam RTT | Morimoto HID | Tyger step bars | LED bed lighting | Midland MXT115 GMRS | Nilight 60w LED 4" pods | RotopaX, Maxsa traction mats and Recovery Gear | ZR2 skids |
Build Thread
Instagram
F8LZ71 is online now
post #909 of 988 (permalink) Old 03-16-2019, 12:00 AM
CC1999's Avatar
New Dmax Bison.
Running same whee and tire combo I have on my 2016.
Wheels
Fuel Anza black with anthrisite grey ring.
Tires
Cooper Zeon LTZ size 285/60/18.
File Type: jpeg 5FBB426E-7452-4DF4-B8C2-CDD98355E5C9.jpeg (85.2 KB, 565 views)
File Type: jpeg 062C6280-6DE2-4B17-A0A2-FB51071F6614.jpeg (89.0 KB, 333 views)
File Type: jpeg 30D44DC5-33A6-4C0D-B970-C19F3C6A1910.jpeg (81.5 KB, 336 views)
lqdchkn, F8LZ71, asesino and 3 others like this.
2019 Colorado Dmax 4x4 White ZR2 Bison
Same wheel and tire combo as the 2016 .
More Mods to come.
2016 Colorado Dmax 4x4 White LT
Icon Stage V Suspension , 1" rear lift blocks, Fuel Black Anza 18x8 Rims, Cooper Zeon LTZ AT 285/60/18 tires, Duramax Tuner tune and Trans tune, Black bow ties, Black OEM fender flairs, lighted headache rack, and rails ,Westin tool box
Other Vehicles
2018 Toyota Land Cruiser
2018 Silverado 1500 LTZ 6.2L 4x4.
2015 RAM 2500 4x4 CTD Laramie
CC1999 is offline
post #910 of 988 (permalink) Old 03-16-2019, 11:04 AM
Originally Posted by Distinct04ZQ8 View Post
The wheels I'm looking at are 20x9 +35 (6.33 backspace). I would like to keep the truck at stock height but obviously don't want to rub and DO want as much sidewall as possible. anybody running a 275/50/20 at stock height? Id prefer to run a 275/55 or 275/60
so what size did you end up with?
hitchman19 is offline
post #911 of 988 (permalink) Old 03-19-2019, 11:44 PM
My 2017 LT Duramax with Trailboss wheels, Toyo Open Country AT in 265/65r17, and Zone 1.25 leveling kit. So pleased with how it turned out.
File Type: jpg 91B262ED-EFC2-45E7-9898-6EECEEE1E299_1553053434737.jpg (165.6 KB, 177 views)
F8LZ71, maxbee25, MaineMan and 1 others like this.
dadonaldson is offline
post #912 of 988 (permalink) Old 03-23-2019, 01:35 PM
Just recived my new DV8 rims from 589 Fab unfortunatly FEDEX damaged 2 of them!
F8LZ71 and asesino like this.
2016 Gmc Canyon CCLB 2.8 Duramax quicksilver
Daveski65 is offline
post #913 of 988 (permalink) Old 03-23-2019, 01:38 PM
Fox 2.5 front coils and rear shocks with DSC tuned by accutuneoffroad will be here tues. :) will post pics :)
ICON UCAs here already.
F8LZ71 likes this.
post #914 of 988 (permalink) Old 03-23-2019, 02:04 PM
F8LZ71's Avatar
Well damn! :(
I can't wait to see that color combo on your truck. I bet you can't either. lol
Build Thread
Instagram
post #915 of 988 (permalink) Old 03-23-2019, 02:09 PM
Originally Posted by F8LZ71 View Post
Well damn! :(
yes i cant wait,,hopefully will install shocks in the next couple of weeks then have wheels and tires installed after i do the suspension.
Yea these were the only rims that i could find with the payload over 3000lbs,,all the other rims were way under,seeing as i do alot of towing.I didnt want any issues.
Thanks for the pics of yours,,went with these as i liked them on yours. will post pics when all installed.
F8LZ71 likes this.
post #916 of 988 (permalink) Old 03-23-2019, 02:21 PM
F8LZ71's Avatar
Get a couple of really nice shots and send them to DV8 and 589Fab so they can add it to the website. All they currently have are photos of my truck with the bronze wheels.
https://dv8offroad.com/collections/w...oad-887-wheels
Build Thread
Instagram
post #917 of 988 (permalink) Old 03-23-2019, 02:39 PM
yea i saw that,,I will def send some there way.
F8LZ71 likes this.
post #918 of 988 (permalink) Old 03-27-2019, 07:54 PM
Was undecided with Black or Chrome wheels, so went with PVD Black chrome.
D1Rk, F8LZ71 and Hunter62 like this.
Allan28 is offline
post #919 of 988 (permalink) Old 03-27-2019, 08:03 PM
pakrbakr36's Avatar
I just painted the gray part black!
File Type: jpg A3ACB92B-A3FE-43ED-8F9C-78D93DA8D1CB_1553731374091.jpg (176.8 KB, 118 views)
pakrbakr36 is offline
post #920 of 988 (permalink) Old 03-27-2019, 10:55 PM
Mack40's Avatar
That looks really good!
Mack40 is offline
