Do you have black oil? - Chevy Colorado & GMC Canyon
 16Likes
  • 1 Post By ti-claude31
  • 4 Post By choneofakind
  • 1 Post By DFlorida
  • 2 Post By Dmross11
  • 2 Post By monteholic
  • 2 Post By EdFlecko
  • 1 Post By Chevnut9
  • 2 Post By 16WhiteColly
post #1 of 16 (permalink) Old 04-13-2019, 11:55 PM Thread Starter
Iamscotticus's Avatar
Ive been hesitating posting this question.
I either feel its a dumb question, or I'm afraid of the answer.
Anyway here it goes..
For the 2017 and up 3.6 LGZ engines only, ONLY!,
Is your used oil totally black, or amber , or somewhere in between?
If you do have relatively clear oil, what oil and filter is used?
I ask this because I thought the newer engines were cleaner and the oils came out cleaner.
But I have had black-as-coal oil since change one. Even when I was doing 500 mile break in changes.
The Blackstone oil reports have been stellar so far, even though I don't use ultra high filtration sub-micron filters.
I use Mobil1 full syn Dexos1 5w-30 and K&N filters. Is the K&N not filtering out the blackness? I wouldn't expect it to. Its high flow, not high filtration. A trade-off Im willing to take.
I have a lot of paranoia riding on this so please be honest!
The blackness probably isn't doing any harm at all so i don't know what Im worried about. Unless the PCV isn't working.
Gawd knows Ive mucked around with it enuf.
Thanks
Iamscotticus is offline
post #2 of 16 (permalink) Old 04-14-2019, 12:11 AM
i dont have black oil,is your k&n filter accordable with synthetic oil ?
Iamscotticus likes this.
ti-claude31 is offline
post #3 of 16 (permalink) Old 04-14-2019, 12:50 AM
choneofakind's Avatar
Dark oil color in itself isn't actually a problem.
https://blog.amsoil.com/why-does-motor-oil-turn-black/
You said so yourself; the blackstone reports are coming back stellar. Why don't you trust the 3rd-party professionals with the science lab who know lubricants?
2018 ZR2 satin steel metallic
1999 Mazda Miata
Slower than a herd of turtles in peanut butter!
choneofakind is offline
post #4 of 16 (permalink) Old 04-14-2019, 01:20 AM
Even 5 mc filters want filter out the black & any filter will work with Synthetic oil , If the oil is turning black in a newer Gas engine within 1000 mi which has no sludge build-up the oil is turning black because of Heat , My oil even after 2000miles in my 2006 I5 is not Black , here a video where he heats New Oil watch it almost turn Black look at temps Heating the oil is at 6:06
DFlorida is offline
post #5 of 16 (permalink) Old 04-14-2019, 04:30 AM
Dmross11's Avatar
......4800 miles on the oil......still looks light amber to me......
ti-claude31 and Iamscotticus like this.
2018 Canyon Denali Metallic Red
K&N Air
Diode Dynamics SL1, Brake, 3rd Brake
Bakflip MX4 Tonneau
Amp Research Bed Extender
Dmross11 is offline
post #6 of 16 (permalink) Old 04-14-2019, 07:09 AM
monteholic's Avatar
I found this.....
Vishwadeep Pal, Mechanical Er || Photoshop addict || Proud MSD fan
Answered Jun 6 2017 · Author has 141 answers and 172.8k answer views
First, color doesn’t necessarily mean anything. Oil can be very, very dark (black even) and still be effective. However, as a general rule:
  • New, clean oil is amber in color
  • As engine oil gets darker, it can indicate a) high heat, b) contaminants, or c) the presence of additives that cause the oil to darken during normal use.
Therefore, the best way to determine what color your oil should be is to observe how your oil changes color over time. Just pull the dipstick every few days, make a mental note, and at some point you’ll learn to “read” your engine’s oil by color, i.e. you may find that your oil starts to look dark brown after 3,000 miles, and very dark brown after 5,000. If your oil is supposed to be changed every 5,000 miles, than you know that “very dark brown” likely means it’s time.
Of course, if you change oil brands or types, all bets are off. Weather can effect color too (to a lesser degree), so diagnosing oil by color is never going to be an exact science.
Some engine oil colors indicate problems:
  • Milky, foamy, and/or cream-colored oil can be indicative of a head gasket leak, especially if you’re seeing white smoke in your exhaust and your vehicle is losing coolant.
  • Thick AND dark oil usually indicates dirt or contaminants. If you’ve gone off-road and exposed your engine to a lot of dust (for example), your thick and dark oil probably means it’s time for an oil change.
  • Oil with a creamy, frothy texture can also indicate water contamination, so if you are NOT seeing white smoke and low coolant levels (or contaminated coolant) in your vehicle, than water would be the next likely source of contamination.
  • Oil color won’t generally be effected by gasoline contamination, but oil smell will change quite a bit, as the oil will smell much like gasoline. Therefore, you don’t need to look at the oil to check for fuel contaminants, you need to smell it.
Iamscotticus and Dmross11 like this.
2019 ZR2 Dusk Edition
2003 LS1 Corvette
1971 Monte Carlo SS454
monteholic is offline
post #7 of 16 (permalink) Old 04-14-2019, 08:44 AM
You should join BITOG - https://www.bobistheoilguy.com, if you're not already a member. Oil, oil filters, flow rates, etc. are discussed ad nauseam.
Suffice it to say that you will never push the flow limits of any of the modern oil filters, but some have much better filtration than K&N.
Just a suggestion.
Ed
16WhiteColly and Iamscotticus like this.
K-9's love to teach suspects that if you run...you'll only be arrested tired!
Support YOUR local law enforcement K-9 Unit!
EdFlecko is offline
post #8 of 16 (permalink) Old 04-14-2019, 05:51 PM
The use of non leaded gas is causing oil to turn blackish, checkyour tailpipe the cold is different now then we had leaded fuel! Don’t worry your oil is fine.
Chevnut9 is offline
post #9 of 16 (permalink) Old 04-14-2019, 06:36 PM
If that was true we all would have BLACK Oil ! My Oil is NOT Black . IS Your oil black ?
Here my oil now with 3202.34mi on it Pennzoil Platinum Full Synthetic & all i use is Unleaded Gas
DFlorida is offline
post #10 of 16 (permalink) Old 04-14-2019, 08:50 PM
16WhiteColly's Avatar
Scott, why have you decided to use K&N filters over AC Delco? Just wondering. Have the AC Delco filters proven to be a problem?
Toughsox and Iamscotticus like this.
See my album for pics
16WhiteColly is offline
post #11 of 16 (permalink) Old 04-14-2019, 09:25 PM
Rangerscott's Avatar
A little tab of oil isnt going to be black unless its been run a long time. You need more volume to see the true color.
Changed out my oil last weekend if the second me free oil from dealer. It was black coming out of the pan. I didnt ha e a light on it so theres that.
At your next change, drain the oil from the pan into a clear tubberware.
Rangerscott is offline
post #12 of 16 (permalink) Old 04-14-2019, 11:23 PM Thread Starter
Its just a warm fuzzy I get of thinking that the bypasses may not be opening as much. How much bypass happens during cold start up and acceleration? Maybe none, maybe more than we know. But with oil pumps and lines blowing in Canada, I was happy to have the K&N in there when its cold down here "ON" Antartica, because no one can be "IN" Antartica.
post #13 of 16 (permalink) Old 04-14-2019, 11:25 PM Thread Starter
Yes. The pleats have never crushed or deformed.
post #14 of 16 (permalink) Old 04-15-2019, 09:42 AM
“ checkyour tailpipe the cold is different now then we had leaded fuel”. Someone is dating his/her self!
2017 laser blue WT extended cab 2WD
South central Indiana
Retired and love it!
V-6 with convenience and towing packages. Added Factory recovery loops (used), factory fog lights (used), tinted front windows, 5" stainless curved nerf bars, tri-fold tonneau cover, bed mat, mud flaps and gel seat cushions.
When posting, remember that it is better to remain silent and be thought a fool than to post a stupid response and remove all doubt
Colorado17# is offline
post #15 of 16 (permalink) Old 04-15-2019, 09:16 PM
Really i don't need to put 6 quarts oil in a clear Tupperware (Not Tubberware) to see if it's BLACK or Darker (Brown) if you can't see that small oil drop on right is darker then you need Glasses or do you need a pan full of 6 quarts of oil in a clear Tupperware to see its darker ????
That oil drop on right is from my Diesel Tractor & you can clearly see its Brown but NOT BLACK , Wow wait I forgot you can't because you need a Clear Tupperware Pan Full of oil before you can tell if its Clear or Darker or Black!
MY oil has never been Black-AS-Coal in any of my Vehicles, that oil from my Colorado has over 3000miles on it and its still Clear & Dmross11: says he has 4800 miles on his oil and its still amber , If you like Black as Coal oil more Power to ya .
DFlorida is offline
post #16 of 16 (permalink) Old 04-15-2019, 10:54 PM
You must be a blast to be around with.
Similar Threads
Black Rims? somichsoldier 1st Gen Modifications - Styling 12 02-13-2008 08:14 AM
Westin Bull Bar - Black or Chrome?? hskrvet 1st Gen Accessories & Aftermarket Products 12 11-15-2007 09:16 PM
Pic Request: Bull Bar (Black or Stainless) On A Black 05 Mattiekrome Videos/Photos 4 01-25-2006 05:24 PM
Black Gas Door on Silver Birch?? Amla613 1st Gen Modifications - Styling 4 01-18-2005 01:51 PM
