Stabilitrak and T/C Warning Light - Chevy Colorado & GMC Canyon
post #1 of 3 (permalink) Old 05-15-2019, 02:06 PM Thread Starter
I started to have these warning lights come on in my truck on a regular basis. For some background my truck has 6400k and is used for driver training so the park brake gets used 50 to 75 times a day. Although the warning lights could be cleared by cycling the ignition for a quick fix the problem remained. After 4 trips to the shop and the dealership replacing the Steering Control Module which requires the pulling of the steering column and a wheel alignment, part of a wiring harness along side of the park brake was found to be worn through. The wiring harness was re-routed and appears to have fixed the problem. I see there has been the occasional post in this regard. I have attached a copy of the work order relating the work done.
File Type: jpg 4B4642EB-7E5D-48C1-877A-3AF7FAED11D6.jpg (314.7 KB, 15 views)
Rick Hopwood is offline
post #2 of 3 (permalink) Old 05-15-2019, 02:41 PM
VAO
I have had that same message and the Service Towing (Trailering?) System at intermittent times as well. Always at startup where I crank her up and it stops cold. I then turn the key again and it starts normally and one of these 2 messages appear. Hasn't happened enough to force me in for warranty work. Thinking these codes don't stick around and if Chevy can't dupe them then why bother?
VAO is offline
post #3 of 3 (permalink) Old 05-15-2019, 03:11 PM
It's a general catch all message, and could be a myriad (word of the day) of things.
I've had the message for a corrupt TPS signal. Others, for a bad wheel speed sensor.
2017 Z71 CCSB, V6, Brownstone Metallic
2017 LT CCSB, V6, Cyber Grey Metallic *TRADED*
2015 Z71 Ext Cab, V6, Red Hot *TRADED*
