Notice a shake on stop light - Chevy Colorado & GMC Canyon
 3Likes
  • 1 Post By DieselDrax
  • 2 Post By evonschu
post #1 of 14 (permalink) Old 05-14-2019, 05:35 PM Thread Starter
Derrick S.'s Avatar
I have notice couple of times that when the trucks is at a stop, it shakes. I feel it's coming from the engine. any ideas?
2015 colorado V6
thanks,
Derrick S. is offline
post #2 of 14 (permalink) Old 05-14-2019, 05:40 PM
Rangerscott's Avatar
Best thing to do is to have a code scanner with "real time" data hooked up so you can see what happens when the shake occurs.
Rangerscott is offline
post #3 of 14 (permalink) Old 05-14-2019, 05:48 PM
pltctycanyon's Avatar
air filter
pltctycanyon is offline
post #4 of 14 (permalink) Old 05-14-2019, 07:13 PM Thread Starter
Derrick S.'s Avatar
replace? or quick clean up...i believe i replace it maybe 6 months ago?
post #5 of 14 (permalink) Old 05-14-2019, 07:35 PM
White016's Avatar
2015 colorado V6
thanks,
How many miles? I would start with a good throttle body cleaning.
As for as the air filter, not likely, just check it and replace if it needs it.
2016 Colorado 4x4 CC SB V6 LT
White016 is offline
post #6 of 14 (permalink) Old 05-14-2019, 07:48 PM
DieselDrax's Avatar
You didn't say how many miles you have on the truck, but I would start by running a bottle of Techron Concentrate Plus Fuel System Cleaner (Not the fuel injector cleaner, which doesn't work as well) and see if that helps. If you're approaching 100k miles then start looking at replacing the spark plugs.
DieselDrax is online now
post #7 of 14 (permalink) Old 05-14-2019, 08:21 PM
I have a 2019 with a LGZ, your 2015 has an LFX. BUT, I noticed mine was doing something similar at stop lights. I started using premium fuel (91) and my truck seems to like that much more and runs smoother. May not be your issue given these are two different engines but it may be something to try.
I remember reading as well that the LFX engine does like premium fuel and other owners seem to be happy with the results.
2019 ZR2 CC V6
Zara2 is offline
post #8 of 14 (permalink) Old 05-21-2019, 12:42 PM Thread Starter
Derrick S.'s Avatar
2015 Colorado V6 miles: 37k
post #9 of 14 (permalink) Old 05-21-2019, 12:44 PM Thread Starter
Derrick S.'s Avatar
I usually add Mid-Grade gas
post #10 of 14 (permalink) Old 05-21-2019, 12:48 PM Thread Starter
Derrick S.'s Avatar
can somebody send a link how to clean throttle body?
post #11 of 14 (permalink) Old 05-21-2019, 12:50 PM
DieselDrax's Avatar
Being that it's a 2015 with only 37k miles you still have the powertrain warranty. If it happens frequently enough for you to take a tech on a drive to show them then it would be good to have them diagnose it as it could be something with the torque converter or similar and covered under warranty. I wouldn't start throwing things at the problem trying to find one that sticks before you see if the dealer will take care of it under warranty.
Derrick S. likes this.
post #12 of 14 (permalink) Old 05-21-2019, 02:30 PM
evonschu's Avatar
Mine was idling real rough sometimes when coming to a stop. One time even stalled. Found out it had a TSB about it at the dealer and to apply a fix to the PCM that raises the idle RPM a little bit and other things. Ever since I had that applied, have had no issues. I don't know the TSB number. But might be worth looking at.
Derrick S. and lafinests like this.
2016 Colorado Z71 Trail Boss
evonschu is offline
post #13 of 14 (permalink) Old Yesterday, 12:55 PM
My 2016 Colorado WT with 2.5L I4 does the same thing. When I am stopped at a light or stop sign, the RPMs drop at idle like it is going to stall. If I put it in neutral the RPMs come back up and it smooths out.
jmac481 is offline
post #14 of 14 (permalink) Old Today, 02:23 PM
I had this problem with my 2016 2.5, although is was more of a vibrating then shaking and only at stops. Took it to the dealer and he noticed it also but couldn't find the problem. They finally called GM and found out there was a service reminder for this exact problem. A hour long reprogramming and problem solved.
If it helps...per invoice, cause: followed 18-na-106
2810075 engine control module reprogramming with SPS
Yates02 is offline
Similar Threads
How To: Morimoto XB Fog light install spoonman 2nd Gen Electronics, Audio, and Lighting 10 08-16-2016 08:08 AM
2x 4inch 18W CREE Led Spot Beam Work Light Offroad Car ATV Truck Boat Fog Lamps Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 11-29-2014 02:40 AM
2x 3156 3157 3457 Red LED 24-SMD Replacement Brake Stop Tail Light Bulbs #S4R Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 10-11-2014 02:50 PM
4x Xenon White 3157 Brake Tail Stop Light LED Bulbs 68-SMD T25 3057 3457 4157 Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 05-28-2014 02:10 AM
HOW TO: Smoke (Tint) Light Lenses (MMP) DBNissan Technical Questions / Tips / How To 101 05-01-2012 10:21 PM
