Keyless Keypad Entry - Chevy Colorado & GMC Canyon
 7Likes
post #1 of 21 (permalink) Old 05-14-2019, 01:31 PM Thread Starter
Keyless Entry System
Part Name: Keyless Entry System
Part #: 23473339
Brand: Chevrolet OEM
MSRP: $125.00
Bought one of these thinking it would be cheap to have the dealer program. Quotes from 2 local dealers to program are 75-85 bucks. I opened the thing before I found this out, and they won't take it back now. Ouch..... live and learn.
post #2 of 21 (permalink) Old 05-14-2019, 02:16 PM
JMB
JMB's Avatar
That's pretty standard for the ~1 hour it takes. The BCM/Vehicle details need to be sent to GM and they send back a one-time passkey for the BCM that allows it to be coded into functioning. It's well worth it IMHO as I use mine at least a few times per week.
2018 Kinetic Blue CCLB Z71
1994 Laguna Blue Miata
JMB is offline
post #3 of 21 (permalink) Old 05-14-2019, 02:34 PM
does the installation of this require cutting into the door?
2019 GMC Canyon Denali Duramax 4x4
bjhinkle22 is offline
post #4 of 21 (permalink) Old 05-14-2019, 02:41 PM
JMB
JMB's Avatar
No, it's backed with 3M double sided tape. Mine is mounted inside of the gas door.
JMB is offline
post #5 of 21 (permalink) Old 05-14-2019, 02:54 PM
i want one now :D
post #6 of 21 (permalink) Old 05-14-2019, 03:01 PM
Folks, go to Chevrolet.com and go to accessories, add the keypad to your cart and select to pick it up at the closest dealer with install. (Purchase it, if you haven't already.) If you've already bought it, print out the cart showing the installation price and show it to your service department and tell them this is what GM says the install cost is.
If your particular dealer won't meet the price, I'm sure you can find a dealer who will.
'19 ZR2 Bison EC Diesel
#IWorkForGM-IT Business Analyst
emulous74 is offline
post #7 of 21 (permalink) Old 05-14-2019, 03:06 PM
I assumed the gas door locks when the doors are locked? I never checked - just assumed.
hoitzed is offline
post #8 of 21 (permalink) Old 05-14-2019, 03:12 PM
greco2003's Avatar
No the gas door never locks just push and open always
2017 Chevy Colorado LT CCSB 2.5L 4cyl, Lazer blue with Bose, navigation, kicker vss, IBoard running boards, Z71 wheels, fog lamps, Drl relocation harness, led fog lights, high and low beam headlights, switchbacks.
greco2003 is online now
post #9 of 21 (permalink) Old 05-14-2019, 03:36 PM
if gas door was locked and you put key pad on inside of door what would be the point?
I need one, when I go biking or running let alone fishing or hunting, do not like to take the keys or fob with me.
greco2003 likes this.
2017 Deep Woods Green ZR2 CC
Truxedo Titanium cover
Go Rhino RB20 running boards
RC level
Hunter62 is offline
post #10 of 21 (permalink) Old 05-14-2019, 04:18 PM
MV10's Avatar
Nothing that costs $125 + dealer setup fee should install with just double-sided tape.
GeorgeT451, weasel1 and Bufffan like this.
2017 Colorado LT V6 CCSB 2WD mfg date 11-16 Belltech 999SP 3/4 drop Raceline 927M Mamba HD 20x9 wheels all LED lighting inside and out DRL relocation harness LineX Lomax Tri-Fold aluminum tonneau de-badged bowtie blackout painted pinch-weld & window trim power tailgate lock Pedal Commander Katzkin leather tint Kicker amp/sub
MV10 is offline
post #11 of 21 (permalink) Old 05-14-2019, 06:55 PM
Rangerscott's Avatar
Install and programming are different.
Rangerscott is online now
post #12 of 21 (permalink) Old 05-14-2019, 07:11 PM
I just checked, and for me it shows dealer install is only $22.50... also lets you add a 10% off coupon which drops the price to ~135.
Interesting thing is, it doesn't let me select the local dealer in Eugene or Cottage Grove (the two closest), but does allow a couple of others that are 20-40 minutes away.
travisn000 is offline
post #13 of 21 (permalink) Old 05-14-2019, 07:30 PM
campermac's Avatar
Just one thing to remember about the keypad and that is that it is powered by a NON replaceable battery which means when it goes dead then you tear it off and throw it away and start all over again and again. That is why I sent mine back as soon as I found that out.
beaglebreath and chefrex like this.
campermac is offline
post #14 of 21 (permalink) Old 05-14-2019, 07:58 PM
GMC18CANYONMT's Avatar
When I ordered my Canyon I added the key-less keypad, but I choose to not have it attached to vehicle. I keep it in accessible location on my 5th wheel.
Non-replaceable battery will last about 10 years.
Dataxman likes this.
2018 GMC Canyon SLT 4wd Crew Cab, DT Dsp4 tune, Clearview tow mirrors, Fold-A-Cover, Anderson 5th Wheel Hitch.
GMC18CANYONMT is offline
post #15 of 21 (permalink) Old 05-20-2019, 07:55 PM
Not a lot of dealers have signed on for the online Chevrolet Accessories. There was only one outside of Austin last year, than another one in Austin came along. I don't know why all the dealers don't sign up for this. My Parts guy says he gets folks from 3 hours away, wait for them to get installed and then drive another 3 hours back. He said he doubled his sales by signing up.
post #16 of 21 (permalink) Old 05-20-2019, 07:57 PM
If you look at the instructions, part of the install is the programming, they shouldn't charge you two different prices for the install. GM does not charge the dealer for the programming.
post #17 of 21 (permalink) Old 05-21-2019, 07:07 AM
fondupot's Avatar
Part #: 23473339
MSRP: $125.00
An automotive locksmith would be able to program it. Typically they are vastly less expensive than a dealer. I just had a key fob programmed for a work truck. The dealership quoted me over $300 for the fob and to program it. I said no thanks. Ordered the fob online for $20, had a local automotive locksmith program it for $50.
fondupot is offline
post #18 of 21 (permalink) Old Yesterday, 07:58 PM
Twan's Avatar
I have one of these things stuck on my driver's door, but no documentation came with it(bought the truck used from dealer). Think I'm just going to pull it off and trash it since reprogramming it seems to involve cards with codes on it or something.
Twan is offline
post #19 of 21 (permalink) Old Today, 10:39 AM
They do come with a plastic card with the codes required to program it to your vehicle. Without the code that they used, you'll never figure out how to unlock them. You can still lock the doors without the code, pressing the 8 and 9 buttons at the same time. If that isn't value to you, than I would suggest removing them, as GM is going to make you purchase another one. They will not reprogram to an existing one. If you bought your truck from a GM Dealer I would go back to them and tell them to either provide the codes or they need to replace it at their expense. If it was a trade-in, they can probably contact the previous owner to get them.
post #20 of 21 (permalink) Old Today, 01:27 PM
to bad the dealer did not know the code, then you could get it re-programmed to what yoou want...
RC level
Hunter62 is offline
Similar Threads
New GM Keyless Entry Keypad - 2015-2019 Various Buick Chevrolet GMC: # 23473339 pjg991 For Sale - WTB - Business Sales 4 04-11-2018 04:03 PM
The fix for keyless entry problems jimK General Truck Chat 17 10-17-2016 06:13 PM
Chevrolet: Colorado LT w/2LT LT w/2LT 3.7L CD 4X4 Keyless Entry Power Door Locks Powe Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 02-20-2016 02:10 PM
Chevrolet : Colorado LT w/2LT LT w/2LT 3.7L CD Keyless Entry Power Door Locks Power M Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 07-14-2014 04:50 PM
Chevrolet : Colorado LT with 1LT LT with 1LT 2.9L CD Keyless Entry Power Door Locks P Chevy Colorado Parts Chevy Colorado eBay Classifieds 0 03-19-2014 09:40 AM
